Hi all,
the aux power board on my big guns keeps blowing the 2 am fuses that seem connected to the swivel gate, Bagatelle ball popper and slings on the play field.
I Have tested the swivel gate, slings, and popper coils and all have tested good with no shorts. I have also re soldered the coils as some of the solder looked warn and old etc. I have tested the transistors on the board (TIP 122), by connecting the common lead to ground and placing the other lead in the hole on the top tab, all tested OK.
however the fuses are still blowing. What else should I test? I traced the wires from the coils and haven't found any breaks. I would rather not have to de solder the 8 transistors on the aux power supply board to test them individually but Ill do it if it were necessary. My other thought is that pinballpcb makes a replacement aux power supply board with modern components and i could just replace the whole thing, but I am not sure that this would solve the issue if there is a short somewhere else.
