(Topic ID: 297209)
AUSTIN POWERS: Some Tech Help Please!
By JCO25
67 days ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 12 days ago by JCO25
#1 67 days ago
So Austin Powers, I've had this machine awhile. Just replaced the pinballs finally, time machine is spinning.
Everything is peachy, then the flippers and pop bumpers just don't produce enough power.
Seems flipper fuses are under the board, so no problem there. Just these two:
1) Ball trough isn't pushing the pinballs out anymore: Coil have to get cleaned or time for a new one?
2) Checked all fuses for pop bumpers. None broken, so do the coils have to get cleaned and/or replaced?
Any feedback would be appreciated. Thanks!
#2 66 days ago
Quoted from JCO25:
Do not clean coils. You can replace the coil sleeve if it's binding and the coil resistance is still within spec.
Per your manual (see chart below) the auto-launch and scoop use the same power line connection as the trough up-kicker. Assuming they are working, check transistor Q1 after you verify you have 50v at the coil lugs.
Since none of the pops are working I'd suspect a broken wire. The power line is yellow/violet for all four of the non-working coils and the other two I mentioned above.
Check those things and let us know how it goes.
#3 47 days ago
For the voltage, is it AC or DC you measure the coil voltage with?
#4 47 days ago
Quoted from JCO25:
So, wait: do the flippers and bumpers completely *fail*, or do they just get *weak*? You need to define terms, here.
#5 47 days ago
The bumpers and flippers just get "weak," not producing enough power.
1 month later
#6 12 days ago
Update: so turns out there was a fuse problem. Called a tech to help me out, but now capacitor c27 on the power driver board has gone out: once on the old board and even on the new board. We found a locked coil under the left slingshot too, fixed it. Anyone know why Austin Powers would burn out C27 on the power driver board?
