New! Dark mode!
(Topic ID: 245839)
Austin Powers Laser Cannon Coil will not fire - any help out there?
By wamonkey
1 year ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by wamonkey
#1 1 year ago
Question - in test the magnet divertor to the laser works, the mechanism moves, the coil will not fire in test or in game play. I have checked all the fuses - all good, I have checked the wiring - all good, I have replaced the coil - still does not work, the fire button works (the sound can be heard on the fire).
Just does not fire. The MPU has no battery acid damage that I can see but I know the main ROM chip is right below where the battery holder is - can't say it never had a leaking battery but it looks super clean.
The wiring is not pinching or binding it all looks good.
Any tips or any help would be appreciated.
#2 1 year ago
Have you checked the plunger to make sure it moves freely in the coil sleeve? There is a test in the settings specifically for the laser, have you ran it with a ball in the cannon?
#3 1 year ago
Quoted from Thrillhouse:
Yes I ran the Austin powers specific test for the laser even putting the ball in the cannon it would not fire, the plunger in the coil is free moving.
I kind of leaning toward a logic issue because the divertor does not que properly during game play but works in test. Just seems like some kind of mpu error. I don’t know why but everything looks good otherwise.
Still no luck to date - just won’t fire even though the fire button works.
#4 1 year ago
I had this problem with my AP and it turned out to be a cold solider joint on the fire button.
#5 1 year ago
Quoted from wamonkey:
Did you check the drive transistor that controls it? Sounds like it's blown. Test Q4 ("laser beam eject) on the board. You'll need a multimeter.
If you don't know how to test, read up on it here:
http://pinwiki.com/wiki/index.php?title=Data_East/Sega#Driver_Transistor_.22Quick_Check.22
#6 1 year ago
I figured it may be a board issue - - I figured something had to be wrong with the logic that makes it fire.
Thanks -
Quoted from vireland:
#7 1 year ago
Thanks -
Do you have a multimeter to test the transistor? They're dead simple to test and relatively easy and cheap to replace.
#8 1 year ago
Yes - I have all that I just hate doing board work just don’t want to damage a irreplaceable board, too hot burn a trace or something then I would be screwed. The board is not available anywhere.
#9 1 year ago
If you have a temperature-controlled soldering iron, it'd be pretty hard to burn a trace, and even then it could be jumpered. First things first, though. Test the transistor to see if it's bad.
And the board you want is 520-5300-00. It's still available some places because Stern made a new batch last year. But you shouldn't have to do that. Transistors are a pretty common repair...
#10 1 year ago
I think I tested it right - looks like the transistor is bad. Used the pinwiki guide....
Thanks all -
$ 208.87
3,500 (OBO)
Claremont, CA
Pinball Pimp
Arcade Upkeep
$ 99.00
Arcade Upkeep
$ 65.00
Lighting - Backbox
Arcade Upkeep
$ 54.99
3,600 (OBO)
Branchburg, NJ
