I have had my gb on location since june. Last month I got and update failure on my node board n8. After about 3 weeks of getting parts to fix the issue she was up and running. I left it on in my shop over night and played a few games all seemed good. So it went back out on location. 3 days later I get a call that it was down again with the same issuse. So it's back in my shop. Called stern today and talk to them about it they said to check the flasher board by the left scoop. Apparently they are having problems with the led board grounding out on the rail for the left orbit and the 48v from the divert coil will back feed to the flasher and knockout everything . So I took the plastic off and sure enough the wire that runs the plus 5v was pinched and had wore though the insalation causing it to ground out. Just thought I would give a heads up to owners because if it's not under warranty it would be a very pricy fix. Here are some pics of what mine looked like. And a pic of what boards it will take out should it fail.
