curious, did they ever fix, it always bothered me a little, they say London Bridge is falling but they show Tower Bridge on the screen
Quoted from Arcade:No kidding.
And the row behind AFMr looks to be
TWD
GB
GOT
Metallica
Tron
and maybe ToTan. Can't quite make it out.
Mystery solved
Quoted from Arcade:Awesome.
Who needs an entire doorway anyway. Right?
Damn right
Lol
Quoted from EricHadley:after seeing your post I checked mine over and didn't find anything like that., Must be a one off issue. Probably not a big deal and won't be an issue down the road but I am sure they'll take care of you.
How exactly will they "take care of him"? They wouldn't send out a populated PF for the faded MMr PF owners so I really doubt they are gonna do that for him. I doubt if they will even offer to send a blank PF and even if they did what customer is gonna want to spend 20 hours plus to swap it out.
No - what he received is what he will end up with. I'd be glad to be proven wrong though.
Quoted from Join_The_Cirqus:Game is amazing!!!!!
Glad To be an Enabler
YOU ARE THE MAN!!!...stellar lineup(s)!!!!
Quoted from Join_The_Cirqus:Mystery solved
Do I see some Moto Glass custom toppers?
Quoted from bigd1979:Still have one question.... does the backbox gi only go out during strobe mb? Or does it go out every time the playfield gi goes out ?
It’s a setting. By default it’s ON, but you can have it match the GI.
Quoted from MrSanRamon:LE # 034 arrives Wednesday between 3 & 6.
Robert
Hi Robert, how did you get notified of your delivery date. (any others for that matter) My distro said mine is coming from CGC direct today(or yesterday).
Does the truck company just call us initially or is shipping info sent another way?
I'm debating between the LE and SE. I'm not a topper guy so would hold and sell it at some point. Did any of you buyers ever see them both side by side? Is the multi colored mini saucers that much cooler looking ? If the topper is worth say, $200.00, then the extra warranty, mirror blades and saucers for $500 is worth it, I think.
Quoted from Budman:I'm debating between the LE and SE. I'm not a topper guy so would hold and sell it at some point. Did any of you buyers ever see them both side by side? Is the multi colored mini saucers that much cooler looking ? If the topper is worth say, $200.00, then the extra warranty, mirror blades and saucers for $500 is worth it, I think.
With the amount of work and the appearance of the interactive/motorized topper does anyone else think it's worth more than $200 or is it just me? I think the LE is the way to go!
Quoted from stpcore:With the amount of work and the appearance of the interactive/motorized topper does anyone else think it's worth more than $200 or is it just me?
I would say it's worth more to me. Look at what stern has for 500
Quoted from Budman:Is the multi colored mini saucers that much cooler looking ?
You get the metal finish tri color LED show saucers on both models.
The LE gets you mirror side blades, better audio, speaker lights, topper, and double the warranty of the SE.
Quoted from Budman:If the topper is worth say, $200.00,
That's a $500 topper. Light show on cityscape background , LED show on saucers, flashers on saucers, Martian eyes light up, Martian bounces up and down. It's amazing.
Quoted from LTG:You get the metal finish tri color LED show saucers on both models.
My SE mini saucers don't have any lights other than the standard flasher, but I do have speaker lights, and I believe the SE and LE both have the same audio components.
Quoted from Pin_Guy:My SE mini saucers don't have any lights other than the standard flasher, but I do have speaker lights, and I believe the SE and LE both have the same audio components.
You are correct. Only the LE has the mini saucer light show. I confused it with the main saucer. Standard has main saucer red chase lights, SE and LE has main saucer tri color lights. and SE and LE has better audio and speaker lights.
Thank you !
Just ordered my L.E. (Green )I'm very happy about this purchase fellas, my distributor in Toronto, ON, told me that mid/late September will arrive.
Cheers!
The topper is THE BEST TOPPER EVER, it would be a shame not to install it.
This isn't your run of the mill topper. It has its own control board in the head unit, and it is complex and completely integrated into game play. Haven't been a huge fan of toppers, but this own is great and adds to the game.
Just had my first malfunction. The diverter was reporting a test error. On closer inspection, the bracket had come loose from the diverter arm. Replaced and tightened the set screw and it's good to go. That set screw may be worth a check. It explains why it was only opening part way from the beginning
Quoted from Knx873:I would say it's worth more to me. Look at what stern has for 500
Was going to say exactly that, the GB one is just an interactive light and it is $549. When comparing the two I felt like the extra $$$ for the LE was a no brainer with how close it was.
Quoted from LP30:Just had my first malfunction. The diverter was reporting a test error. On closer inspection, the bracket had come loose from the diverter arm. Replaced and tightened the set screw and it's good to go. That set screw may be worth a check. It explains why it was only opening part way from the beginning
Maybe put a little blue loctite on that set screw.
Quoted from MrSanRamon:I just refused delivery of S/N 34...shipping damage.
Robert
Hard to read to be honest, and I hope that your distributor will get you a replacement soon Robert. My Brother had some issues with his Batman66 L.E. so I understand perfectly what just happened to you.
Regards.
Quoted from Rolls-Royce:Hard to read to be honest, and I hope that your distributor will get you a replacement soon Robert. My Brother had some issues with his Batman66 L.E. so I understand perfectly what just happened to you.
Thanks.
Robert
Robert
My heart sank when I saw that picture, sorry man. Hoping it gets replaced quickly.
Robert
Dang! Sorry man. Who was the shipper? Looks like they carelessly ran a forklift into it.
Quoted from EricHadley:Dang! Sorry man. Who was the shipper? Looks like they carelessly ran a forklift into it.
XPO Logistics.
Quoted from EricHadley:Here is more eye candy AFMr LE with Grey Titans!!!!
... ohh wow man! Congrats WackyBrakke, that looks extremely nice! What number did you got?
Stopped by my buddies house and played his LE last night. Played like a dream and looks amazing. Topper, black trim, playfield clear coat was like glass with no dimples. I will be picking one up asap.
Quoted from Rolls-Royce:... ohh wow man! Congrats WackyBrakke, that looks extremely nice! What number did you got?
#669 to match my MMr LE
Quoted from woody76:Stopped by my buddies house and played his LE last night. Played like a dream and looks amazing. Topper, black trim, playfield clear coat was like glass with no dimples. I will be picking one up asap.
Are you gunna get black or green?
Quoted from bigdaddy07:Its hard to tell in the pictures, but is your SOL hole protector level with the opening?
It looks low in the pics. It should rest no more than 1/64" below the surface, flush would also be good.
Is there any advantage to getting later shipments on these games? For example will some of the issues be ironed out before later shipments are sent?
Quoted from Damien:Is there any advantage to getting later shipments on these games? For example will some of the issues be ironed out before later shipments are sent?
Mine is rock solid, not sure there are any issues to iron out.
Quoted from EricHadley:Mine is rock solid, not sure there are any issues to iron out.
Even little things like SOL protector being installed too low...
Quoted from Damien:Even little things like SOL protector being installed too low...
Fine on mine
meh, that will vary just like everything in pinball. No big deal
This page was printed from https://pinside.com/pinball/forum/topic/attack-from-mars-remake-afmr-owners-club/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
