(Topic ID: 192072)
Attack From Mars Remake (AFMr) Owners Club
By Pin_Guy
  • 9,734 posts
  • 634 Pinsiders participating
  • Latest reply 1 day ago by Green-Machine
  • Topic is favorited by 289 Pinsiders
26 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 9,734 posts in this topic. You are on page 43 of 195.
#2101 3 years ago
Roughly how much would the backbox weight if I slide off the glass and speakers? I'm curious in case I ever need to move it, I think it would be easier and less chance of damage if I remove the backbox...
#2102 3 years ago
Quoted from IonRay:
Also new out of the box the cabinet directly behind the glass channel / under the back box is flaking. Note flakes of paint on the playfield glass in this image.
I have similar flaking I the same spot but almost completely from one side to the other. Did you open a ticket for this? If so, did they offer an resolution?
#2103 3 years ago
Can anyone advise
Set up afm found topper motor won't work lights etc all ok but no martian action
Bigger issue
Played about 6 games of doubles and was just swapping over after a very average ball and NOTHING almost if someone pulled the power checked fuses also the 2 at the switch inside the door swapped power cable checked headbox fuses checked power supply at wall all ok but there are 3 leds in headbox on already opened ticket but has this happened to anyone
#2104 3 years ago
Quoted from john17a:
Can anyone advise
Bigger issue
You don’t have your topper fully hooked up based on that picture as I see a connector not connected.
#2105 3 years ago
It looks like you haven't plugged in the motor connection on the top board, the open position on the top right. The connectors are marked and one states "motor". It also seems you have two open connectors...
#2106 3 years ago
Very pleased to join the club. I played well right out of the box, but will need some tweaking. Overall very impressed.
#557 with #675 PF.
#2107 3 years ago
Quoted from SuperHomer:
I mentioned this in the same support ticket with my non-functioning topper. They did not bring this up. And there have been no further updates on the ticket since Thursday.
#2108 3 years ago
Quoted from snaroff:
No change. Like you, a ticket was filed.
snaroff
Ugh! Well at least its a little comforting that there's another out there.
Hope we get this sorted out soon, its starting to turn me off the idea of buying NIB pins.
#2109 3 years ago
Quoted from IonRay:
I didn't understand why some would not want NIB, but now I get it... I think it's so hard for the manufacturer to get the build perfect with so many moving parts and test edge cases, it's up to the first owner to test/tweak it.
Do the NIB Stern pins also have these types of issues?
#2110 3 years ago
Quoted from bitpatrol:
Yep All manufactures do to some degree. These games used to go mostly to operators. They had techs or were techs and it was a commercial purchase so little cosmetic issues were not really a problem. Today home use market we are picky and want the machine to look and play near perfect right out of the box. (the way it should be in my book) But it takes some set up, adjusting and sometimes dependency on the manufacturer to get the game playing properly. I am sure CGC will get you straightened out and playing properly!
#2111 3 years ago
Quoted from whthrs166:
Yeah, I have no doubt that CGC will get it all worked out in the end, but for the moment it's super frustrating!
There's plenty of posts on issues from just about all manufacturers and there's a lot of parts going into these things and totally understandable that things will need to be adjusted and setup by the end user but AFM LE is supposed to be *the* machine that is perfect out of box.
#2112 3 years ago
My #254 playfield #836 ran perfect out of the box with no issues. I did have to move the left and right outlane stoppers to the middle as they were not tight and had moved all the way up. I installed full cliffys ( kept mantis in SOL as I think it's better than the cliffy for that hole ), full playfield protector, felt lined metal washers for the legs, full plastic protectors set with not 1 scratch or blemish on it, not even on the cabinet/backbox. There was a loose ring, plastic washer and screw in the bottom of the cabinet when I unboxed it, but no parts were missing anywhere so they must have fallen in during manufacturing. I also have the shooter lane cliffys installed, was not that difficult with a clamp. Removing the pressed-in posts is actually super-easy with no hammering/tapping required, just vice grips with electrical tape around the ends to prevent scratching, removing the post rubber and gripping/twisting the posts out slowly with little force. Putting them back in was the same, super easy when twisting them in with a bit of force, but it nudges in slowly. I wore rubber gloves too while working on it too so no finger prints anywhere I used a digital level to adjust it perfect at 6.5 as the analog one that comes with it is off.
#2113 3 years ago
Quoted from IonRay:
Please post on your ticket again.
#2114 3 years ago
Well I noticed my outlanes had slid up as well, moved them all the way down after wanting to throw the thing outside from all the constant outlane drains. I adjusted my left flipper again as it still seemed a bit off, and it actually seems like the head of the flipper is a bit higher then the right flipper...will take a pic later to show what I'm talking about. At any rate, very first game with the outlanes moved down:
#2115 3 years ago
Can anyone advise
Looks like you have a cable disconnected, please see this post and the following solution from LTG
https://pinside.com/pinball/forum/topic/attack-from-mars-remake-afmr-owners-club/page/8#post-3923286
#2116 3 years ago
That's that free bonus stuff!
#2117 3 years ago
thanks for replys on the topper but the real issue is game no power could be related to switch power supply lost power
has anyone had this issue
thank you
#2118 3 years ago
yeah it looks like the controller board has no power.
#2119 3 years ago
Did you verify with a DMM. Easy enough to check
#2120 3 years ago
Its gotta be something like a cables loose or bad connection.
#2121 3 years ago
Quoted from hoby1:
Did you verify with a DMM. Easy enough to check</blockquote
no i havnt not sure what to do > following cgc instructions but time differance makes thing hard might have to stay up tonight
#2122 3 years ago
Try disconnecting the topper from the main board. See if it changes anything. Maybe the coil on the topper is shorted or something. ( I dont know but ya gotta start somewhere. )
#2123 3 years ago
and game stopped in between balls DEAD like power outage only sign of life is the 3 leds in back box
#2124 3 years ago
Open coin door. Pull out high power interlock switch. Play a game. If game works, the flap closing the switch needs adjustment.
#2125 3 years ago
Quoted from LTG:
Tried that Lloyd no good what else do you think
#2126 3 years ago
Take your DMM and measure voltage at the cpu board.
#2127 3 years ago
I gonna say hes missing some kind of voltage from the switching P/Supply. Not much lit on his boards.
#2128 3 years ago
Hopefully it’s just a fuse.
#2129 3 years ago
Obviously, the connection to the translite is open but that shouldn't make a difference.
You referred to the topper not working, those better versed may be able to explain it better but one of the connectors has a block installed from the factory to "key" the connector. IOW, you either pull the blocker or cut one of the pins to make it fit.
I do not have the topper installed but maybe this picture may be a help.
#2130 3 years ago
Quoted from BagAJellyDonuts:
If thats the case ...... uuuum, thats not good.
#2131 3 years ago
OK looking at the solenoid control board schematic it looks like 12v comes in from the transformer to j104 then over to f106. Check f106 (fuse) also see if j105 sends 12v over to the controller.
#2132 3 years ago
also check F105
#2133 3 years ago
Actually it Might be J102 It says Controller on it in the schematic. Check for 12v at pin 1. J102 is at the top left corner of the Solenoid Control Board (right one)
#2134 3 years ago
You really need to plug in everything as needed, the picture you showed was missing at least two connections as required....and/or you plugged them in wrong and the machine blew a fuse. There really should not be any problems if done correctly and as documented in the manual....
I understand that there are plenty of Nu-bees here buying these NIB pinball machines, but really, read the manuals.....Starting from the front, it has a wealth of necessary information.
#2135 3 years ago
Quoted from TheMickster:
What plugs are you looking at so he knows. I actually thought the one on the bottom left was but looking closer it is plugged in. Lets help the guy out.
#2136 3 years ago
Those two connections are not his problem.
#2137 3 years ago
He needs to check his fuses with a dvm.
#2138 3 years ago
Hes on his way home now and hes going to start by checking his voltages at the PS first.
#2139 3 years ago
I was referring to John17a topper not working, otherwise always check for loose connections, I really don't think it is a factory issue at this time, but in seeing the missing connections with the topper, not sure if something wasn't hooked up wrong from the beginning is all. Sorry, but FYI, 25+ years doing this is my background.
#2140 3 years ago
Now I might be crazy...but was hoping someone can help me....
It seems the balls are slamming into the targets and ramps too hard or fast....Can this be adjusted???
#2141 3 years ago
Quoted from RichieWrench:
Lower the flipper strength.
#2142 3 years ago
Quoted from abagwell:
Congrats on the RTU!
What do you have your flipper strength set to?
I seemed to be getting really decent scores at default setting, but then reduced the strength to prevent air balls and have noticed a dip in my scores.
Also find it very hard to get the 5-way combos.
Anyone else notice this difference when lowering flipper strength?
#2143 3 years ago
I actually have my flipper strength set at 22 and it feels perfect. Hit an 8way combo last night. Man did that feel good
#2144 3 years ago
Might be time to open the outlanes back up- at least to half way.
#2145 3 years ago
Quoted from LTG:
I have a question. I have my afmr leveled and set to 7.2 degrees with min flipped power and I'm still getting air balls non stop. I kinda like the air balls but the playfield is taking too much abuse. Is there something I can do to fix this?
#2146 3 years ago
Quoted from hoby1:
Looking at the picture the unplugged connector that is black and white (the one with the pin plug in it) goes on the lower right connector.(need to cut the pin or pull the little white plug). The connector currently in the wrong spot goes up top in the empty 4 pin spot. The circuit board is clearly labelled for each connector.
I assume having things connected wrong could cause other problems and may have blown a circuit or chip or something. I would start by connecting topper properly or unplug it alltogether to start.
#2147 3 years ago
Right flipper has stopped working and I am getting this error message any ideas how to fix it?
I’ve had less than 30 plays on it
#2148 3 years ago
Quoted from Dust2000:
End of Stroke switch. If you’re not sure what you’re looking at take a picture of the right flipper mechs (from the bottom of the play field) and post it here so we can take a look.
#2149 3 years ago
Check if the fuse (F115) is blown. If it is, file a ticket with CG...
snaroff
#2150 3 years ago
Quoted from Damien:
I have mine at -18, wasn't having any issues making shots, though I always feel like the 5way is such a crap shoot, especially if you are trying to alternate ramps. I try and mix in a lock when I'm going for it to give myself a break or wait until my orbits are open. Also I was looking at the original AFMs high scores on here and people were saying that they "3x RTU'd", but after I finished RTU the game didn't reset. It just stayed with every city lit solid, Mars was flashing, and the saucer drop bank stayed down with the back target up. Every hit on that target for the rest of my game gave me 100M. I had several balls left after I RTU'd and this never changed...how are you supposed to 3x RTU or was that something they changed in this remake somehow?
