Quoted from mpnox:So I am getting a lot of airballs off the right ramp and hits the glass (if not down the shooter lane or elsewhere)
Lowering flipper power is a solution I know and I have lowered it a bit but is there any other way to solve this?
It is just the right ramp that is the problem. Sometimes I do get some airballs when I hit the ship in an attack wave but they never hit the glass.
I also get air balls when the gate is down below the mothership, and the target in front of the hole is also down. The ball will hit the metal scoop and either fall in behind it or bounces back out not making it down the hole. This seems to have started after I installed my playfield protector, but I also reset to manufacture'rs defaults which did change the game setup from when I first unboxed it. Maybe the flippers are set stronger now. ( I did the reset just after I isntalled the pp )
Should I try moving the gates up a bit when they are in the lowered position, so that it is more flush with the playfield/plastic protector? The ball does get hung up in that spot when the gate is lowered sometimes. After 10 seconds the gate comes up and the ball comes down, but not sure if that is also caused by the pp or if the gate lowers too deep, not being flush.
