Quoted from JoshODBrown:Can someone confirm if there is a way to make the new color DMD show orange/red dots only like the original machines. I know this is a stupid request but is there any way it can be done in the menus?
Quoted from LTG:LTG : )
This is awesome! Thanks for confirming that! Didn’t have a game in front of me to try it, but needed to know if it was capable of doing so.
Ugh, You sir are a saint. This will be very helpful. Thank you.
I've played games with all of the color options, but keep coming back to full color. AFMr has to be one of the best overall animated pins from the DMD era, and the enhanced resolution and color on the larger display only make it better.
Quoted from CoasterG:Out of curiosity, you need the color chip, larger display, the proper mounting for the display - anything else?
Where did you get your larger LCD screen from?
I believe I ordered from Jason at Classicgamerooms.com…but I know he is out.
Yes, color chip and the XL display kit…which includes everything needed to upgrade the display and subwoofer.
I found this YT video pretty informative.
Quoted from TheMickster:For those they do not have these Big O Jiggly Martians, with or without the LED eyes, you are missing a great enhancement for your playfield.
AFM & AFMr Big O Jiggly LED Martians, Red or Multi Colored Eyes
Big O Jiggly Martians, no LEDs, Just Bigger and Jiggly
Thank you all for the continuing support of my products,
Mick
Just wanted to give a big shout out to Mick for providing great customer support.
A tiny led went out on one of my Big O Jiggly Martians and Mick immediately provided a replacement without any hassle.
For those who haven't upgraded their original martians, the Big O jiggly Martians are a nice improvement. And you can have confidence knowing the seller stands by his product. Thanks Mick!
Quoted from Richard-NBA-SF2:Any suggestions?
Gently bend the wireform a little to make more of a banked turn.
Raise the wireform a little where it fastens on the slingshot plastic.
Raise the rear of your game so the playfield is more steep.
Quoted from LTG:Gently bend the wireform a little to make more of a banked turn.
Ok!
Should I try one of these steps at a time?
I’ll start by trying to bend it first.
As far as raising the wire form a little, should I put little washer under it?
Thanks again Lloyd!
Richard
Quoted from Richard-NBA-SF2:Ok!
Should I try one of these steps at a time?I’ll start by trying to bend it first.
Try any one you like first.
To raise the wireform a washer, washers, spacer, etc. etc.
Quoted from LTG:Try any one you like first.
Got it, will try soon.
Thanks again Lloyd!
Richard
Hello all…. Need to pull my side rails as I am going to send the off for powder coating soon.
Do I need to pull the head for that?
Thanks in advance for any tips!
Matt
Quoted from medic7000:Any idea if GCG will remake AFM
Haven't heard anything like that.
Quoted from medic7000:if they might sell toppers separately like MM?
No.
Quoted from Richard-NBA-SF2:Finally installed my LerMods lighting, its cool.
Looks good.. Try to get the Eat at Eddies mod for the ugly VUK!!
Quoted from Baggerman:Looks good.. Try to get the Eat at Eddies mod for the ugly VUK!!
Here is Mezel's, but they are unavailable (not sure if they are still making them): https://mezelmods.com/collections/attack-from-mars-pinball-mods/products/attack-from-mars-pinball-eat-at-eddys-building
However, there's always my VUK building cover. I wanted something more in style with the building in the game's artwork, and I can customize the message on the sign: https://pinside.com/pinball/market/classifieds/ad/100908
Mezel runs out so get on the mailing list to be notified when back in stock. I think the Eddy building and big wiggly
Martians are the best mods for this game
Mezel was out when I looked a few weeks ago. I purchased the same one from Cointaker:
https://cointaker.com/products/attack-from-mars-eat-at-eddys-building
Quoted from tktlwyr:Mezel was out when I looked a few weeks ago. I purchased the same one from Cointaker:
How do they attach?
Quoted from matt68061:Hello all…. Need to pull my side rails as I am going to send the off for powder coating soon.
Matt
AFMr rails unscrew on each side. Don’t need to pull the head. Easiest game ever to take them off.
Quoted from Richard-NBA-SF2:How do they attach?
Basically just sits over top of the VUK and uses double-sided tape.
Quoted from cconway84:Here is my AFMr that I powdercoated.
[quoted image][quoted image]
cconway84 - thanks for the info and pics! What color is that?…am I seeing a bit of metal flake in there?
…also thinking of doing my MM in a deep royal/cobalt blue. Those each look great!
Quoted from matt68061:cconway84 - thanks for the info and pics! What color is that?…am I seeing a bit of metal flake in there?
Similar color to a LE. A touch more subtle. More granny apple less neon green.
I saw MMr in blue on pinside and had to copy it. Love the look.
Looks great!
I don't know about Mezel's, but mine is just a slide over the VUK chute friction fit.
Quoted from cconway84:Similar color to a LE. A touch more subtle. More granny apple less neon green.
Looks like you own stock in CGC with that great lineup
Quoted from Mr_Tantrum:I don't know about Mezel's, but mine is just a slide over the VUK chute friction fit.
Ok! I have a shaker in my AFMr SE. would that ever to cause it to come loose?
Quoted from Richard-NBA-SF2:Ok! I have a shaker in my AFMr SE. would that ever to cause it to come loose?
No, I also have a shaker in my LE and I've never adjusted mine nor had reports of people having to do so. You can always stick a piece of mounting tape on the inside if you want (or I can also include a magnet on the inside). Can't tell you how many of these I've sold to both original and remake owners, so they are always welcome to comment on their experiences.
I removed the green trough light… this looks better to me!
Quoted from Mr_Tantrum:No, I also have a shaker in my LE and I've never adjusted mine nor had reports of people having to do so. You can always stick a piece of mounting tape on the inside if you want (or I can also include a magnet on the inside). Can't tell you how many of these I've sold to both original and remake owners, so they are always welcome to comment on their experiences.
Use the double stick tape on it.. will never come loose. I did that and have shaker never budged.
I added one washer tonight. Seems to do the trick.
Thanks Lloyd.
RIP Lyman
Or maybe candy electric blue by Robert Stone? Looks effing amazing!
Quoted from medic7000:Is it recommended to remove the topper when transporting the game in your vehicle?
My LE went 9 miles in a truck folded down with topper in place with no issues.
Quoted from medic7000:Hello. Lermods led strips or pinstadium?
I like my lermods light strip in the back.
Anyone have the instruction sheet for the install of Mezel Mods “Eat at Eddie’s” mod?
Richard
Quoted from Richard-NBA-SF2:Anyone have the instruction sheet for the install of Mezel Mods “Eat at Eddie’s” mod?
Richard
Edit:
Just found it on their site!
https://mezelmods.zendesk.com/hc/en-us/articles/360006667734-AFM-Eat-at-Eddy-s-Building
Quoted from medic7000:I bought the led eye jiggly o martians. Do you recommend attaching the lights to general GI or a more interactive light? Also silver sharpie to make this look better? Detail is not there compared to original
Before I had mine painted, I used a silver Sharpie to make them look more like the Martian on the LE topper. I also used a red Sharpie in the eye area.
As far as lighting them, I connected them to GI and really like them that way. It's hard to do anything other than that due to the SMDs being surface mounted to circuit boards. Besides, I like those beady red eyes staring at me while I'm trying to destroy their mothership.
Here are my painted once. These have a slight blackwash on them to bring out detail, silver exposed muscles, and some coloring on the head.
I had an issue occur yesterday that I don't know if it was a fluke or a documented issue/bug. I was in total annihilation multi-ball with the forcefield down and destroyed the last saucer before destroying it and advancing to destroy Mars. The game didn't stop and play the normal animation for advancing to destroy mars but the forcefield raised as normal and I kept playing until multi-ball finished.
Once multi-ball was over I was able to hit all 3 targets and lower the forcefield (this occurred while still playing the remaining ball from multi-ball and after draining and launching a new ball). At this point, I kept hitting the saucer target over and over, but the destruction of Mars animation never occurred. I did this well over 10 times (probably close to 20) but nothing ever changed. The drop target would drop, my ball would go down the chute, and it was returned to the flippers via the left wireframe.
Very frustrating as a I had really nice game going (I actually set my high score even with this bug), and only had one achievement left before advancing to RTU (which still eludes me).
