Quoted from Marcdaddy:Thanks, I think it did make sense to submit it just to be safe. Thanks for all your help!!
The SOL scoop is pretty easy to remove. CGC did an awsome job of modularising the game.
Im afraid replacing the assembly wont fix it. Unless you get them to dremmel out the upper holes for you.
The screws that would affect the angle of the scoop were applied via pre-dimpled locations.
The assemblers just applied them with a screw gun as needed.
With the screws in place now there is only one option. Widen the 2 upper holes in the mech about 1/16" to the right and twist it to the left when re-installing it. Use a dremmel (faster) or sidecut with a drill bit (slower). The lower machine screw holes have enough play that they probably dont need adjusting.
No solder needed, 2 machine screws, 2 wood screws, 2 connectors.
The scoop removes in 3 mins. 2 mins to reinstall.
Take the balls out first to be safe.
