(Topic ID: 192072)
Attack From Mars Remake (AFMr) Owners Club
By Pin_Guy
  • 8,607 posts
  • 534 Pinsiders participating
  • Latest reply 6 days ago by dugmar
  • Topic is favorited by 260 Pinsiders
There have been 1,652 images uploaded to this topic. (View topic image gallery).
26 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8607 posts in this topic. You are on page 172 of 173.
#8551 36 days ago
Quoted from LTG:
Bottom.
The master has spoken wisely.
#8552 36 days ago
That’s the same as taking the rubber off and aligning the bottom of the flipper to the toothpick. I guess it’s preference but what is the correct factory alignment. I got 2 different opinions. LTG, care to set the record straight please.
#8553 36 days ago
Quoted from yuriijos:
If you stick a tooth pick between the rubber ring and bottom of the flipper, and poke the tooth pick into the roll pin pounded into the playfield. It's easier to tighten the pawl nut and have the flipper aligned right. ( you still need to be mindful of a tiny bit of up and down play )
If you take the rubber ring off. And stick a tooth pick into the roll pin at the bottom of the playfield. Then lift the playfield up to tighten the pawl nut, the flipper could slip back the other direction and not be lined up at all.
Me. I just eye ball it. I tighten the pawl nut so the flipper bat can be turned with a little force and stays put so when I lower the playfield I can set it where I want it. I use the roll pin as a guide, no tooth pick, yet try to line the flipper bat so it lines up with the lane guide. And then crank the pawl nut tight.
It's your game, set it up so it plays the way you like. Some games like the flipper bat a little higher, some a little lower. So you can shoot shots better.
#8554 35 days ago
Finally read through all the posts... looking forward to joining the club with my first pinball ever. Anyone know of any distros with CE at retail price still, or a used one in northern california? Will they be manufacturing anymore once this pandemic blows over?
#8555 35 days ago
Flipper alignment question. I stuck a toothpick in the holes and aligned the flippers so the bottom of the rubber is just touching the toothpick when straight up. Is this correct or is it done without the rubber on the flipper?
I prefer this alignment as the entire edge of the flipper will be in direct alignment with the inlane ball guide and my game seems to shoot better with this flipper alignment.
#8556 35 days ago
Quoted from LTG:
I did this with my Houdini.
I lowered the flipper angle just slightly kinda like AFM and it now shoots wonderfully.
#8557 35 days ago
Quoted from Pin_Guy:
I’ll have to agree, I think I found my sweet spots. 1 shot away from ruling the universe since I aligned them this way, Damn! Tweaked the SOL eject just right and the game plays sweet right now.
#8558 29 days ago
I know this has been addressed before so if anyone can point me to the number reference I will appreciate. I have a problem with the VUK on the left ramp, as well as the auto ball loader. They both are not loading the ball always on the first try and sometimes it takes 3 to 4 tries to load the ball. I already checked the computer adjustments and they are fine. Is there any other mechanical adjustment that could be made?
#8559 29 days ago
Quoted from AvidPinPlayer:
Bend the VUK a little. As for the shooter, contact CGC with your serial number, you may need a new ball guide.
#8560 25 days ago
Quoted from Thomas3184:
This game is done being made...
#8561 25 days ago
Quoted from pintechev:
Bend the VUK is kind of generic, bend black upright part what way?
#8562 25 days ago
Quoted from PunishersLEMC:
Thanks. I asked one distributor who said CGC might be doing another run next year. That may be pure speculation, who knows?
#8563 25 days ago
If there is a demand they will make some.
#8564 25 days ago
The mechanism under the playfield. You can bend it it so that the ball hits the black chute at a different angle.
#8565 25 days ago
https://www.dropbox.com/s/pjnidctcncvd7zw/Popper%20Alignment.mov?dl=0
#8566 24 days ago
I just received the custom backglass (real printed glass, not a translite) I had made, so thought I would share with the group. I kept with the original theme, with just a couple of changes. First, I got rid of the credits at lower left, second, I lowered the street lamp so as to not interfere with the sign, and third I integrated my son's name into the game. Instead of "Eat at Eddy's" the sign now says "Zane's Arcade". I then customized the sign on my building to say "Play at Zane's". Something fun to do, and he got a real kick out of it.
#8567 24 days ago
Quoted from Mr_Tantrum:
I just received the custom backglass (real printed glass, not a translite) I had made, so thought I would share with the group. I kept with the original theme, with just a couple of changes. First, I got rid of the credits at lower left, and second I integrated my son's name into the game. Instead of "Eat at Eddy's" the sign now says "Zane's Arcade". I then customized the sign on my building to say "Play at Zane's". Something fun to do, and he got a real kick out of it.
Loving it!
#8568 23 days ago
What, no Comic Sans? Heresy!
#8569 20 days ago
Joined the club today after a long time waiting and searching! I now have a mint AFMR SE with Eat at Eddy’s mod, pinblades, alternate art backglass, lit trough and shooter lane and alternate apron art. Super happy with it so far!
My only issue is that the original owner did not install the head bolts and when I try to install them they get very hard to turn after about the first 1/4 inch, almost like they are slightly larger than they should be? Anyone else have this issue? I hate to try and force them to turn for fear of stripping the threads.
#8570 20 days ago
Quoted from Pinball_Gizzard:
Get a tap and rethread them.
#8571 20 days ago
Where are the pics?
#8572 20 days ago
Quoted from LTG:
#8573 20 days ago
Where are the pics?
My sincere apologies!
#8574 20 days ago
Looks good. Nice pick up.
#8575 20 days ago
My sincere apologies![quoted image][quoted image]
Nothing to apologize about, but when you get people all excited about your new pin acquisition we want to see it. Nice looking pin, and congrats!
#8576 15 days ago
Anybody know where to get the translucent green stand up targets? I ordered from Pinballlife, but they're the opaque green for the original AFM. Thanks.
#8577 15 days ago
Quoted from WizWiggy:
http://www.planetarypinball.com/ If not on the website. Email Sara and see if they can get them from CGC.
#8578 15 days ago
Quoted from LTG:
You have to tell PP that their online catalog system truly sucks. It is by far the absolute worst of all pinball suppliers. It is non-intuitive, difficult to browse through, and you have to go through a maze to find parts you are looking for. When I have had to buy parts there, sometimes I search for something and it doesn't show up, but when I somehow browse through things the part/item is there.
I think a more user friendly interface would immediately increase their sales just because people will want to come to the site and actually be able to find what they are looking for.
For some examples that are 100x better see pinballlife.com, marcospecialties.com, cometpinball.com, etc.
#8579 15 days ago
Your probably ordered these: https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=a-18018-21
When you should have ordered these: https://www.pinballlife.com/williamsbally-3-ddeep-transparent-green-square-target.html
#8580 15 days ago
I was finally able to play cow mania in video mode where your shooting cows instead of saucers. I have read about this in the Easter eggs for this game and your suppose to hit the right launch button repeatedly when you shoot either the left or the right ramps and you see the cow being beamed up. Funny thing is I have yet to get it this way and the other day when I was playing I guess I got it randomly because i was not hitting the launch button on ramp shots. Is it truly a random event and if so can you increase the odds in the settings somewhere?
#8581 15 days ago
Good for you, hope it gave you a good laugh. I’ve still not been able to do it, as I guess I’m not doing something right.
#8582 15 days ago
I got the cow video mode once as the 2nd video mode in the same game after shooting down the mother ship in the 1st one.
#8583 14 days ago
You only have to push the launch button when you shoot the ramp and get the cow video, you will get a "mooo" sound everytime you hit the button while the cow is active. You need BOTH left and right ramps to register the cows so if you shoot either of these ramps during skill shot to complete the ramp, you cannot qualify the cow video mode.
#8584 14 days ago
Yep, makes sense, but the other day I didn’t do any of that and I still played the cow video mode as if it were random. Explain that. Lol.
#8585 14 days ago
Drunk, high.
#8586 14 days ago
Just finished a decent game, couldnt get cow video mode, but got Dirty Pool for the first time ever.
11
#8587 13 days ago
Check out the custom mod my daughter made me for father's day. It's named after our local coffee shop / pinball parlor.
#8588 13 days ago
Quoted from Glangas:
Nice...much better than my Father's day gift of a card!
15
#8589 13 days ago
My project last night, custom painted Martians!
Before: boring green Martians. They look sad.
After: Exciting, much happier Martians!
3C464B5C-91FF-4470-A05F-A6B8A7C325AD (resized).jpeg578FE912-0160-4C56-ADD0-75CAEFFF21D6 (resized).jpeg2474D635-3BCC-400D-9E76-B69D7ECF6271 (resized).jpeg403A5B0B-36F1-42B6-B770-D108ED5FB626 (resized).jpeg
#8590 13 days ago
Those came out AWESOME! Nice work.
#8591 13 days ago
Cool work, they rock!
CGC should have done something like that with the AFM remake, at least in the LE's
Ps: would you paint my aliens if i send you?
#8592 13 days ago
Quoted from sonambulo:
I’d be open to painting some aliens if you want. The shipping would be expensive though.
#8593 13 days ago
How much to paint a set of 4? I'd love to have mine done.
#8594 13 days ago
Quoted from Only_Pinball:
I have no idea. How about $50? You ship to me and I'll paint them and send them back?
#8595 13 days ago
I will 100% vouch for Pinball_Gizzard
Rick is a personal friend of mine and an all around great guy. He has painted some Jurassic park dinosaurs for me before, and they came out incredible!
The paint job on the aliens looks 1000x better than the originals.
#8596 13 days ago
Ahh, that's awesome. Congrats, Dad!
#8597 13 days ago
Those look great. I already have the Createx paints, so I'm more interested in your technique. Any pointers?
#8598 13 days ago
Sure, first I blocked in the main colors. I mixed a more yellow/green color for the highlights. I then used washes to bring out the details in the sculpts. After that was dry I went back over some areas with highlights to bring them back out a little. Last touches was just some detail work on the mouth, eyes, brains, etc.
#8599 13 days ago
Thanks. However, I'm a model painting newb, can you explain "washes" technique to me? I assume this is what created the darker parts that give definition.
#8600 13 days ago
Where are you located?
$ 279.95
Pin Stadium Pinball LEDs
$ 135.00
Cabinet - (Alt) Translites
Lit Frames
$ 79.00
