(Topic ID: 192072)
Attack From Mars Remake (AFMr) Owners Club
By Pin_Guy
  • 8,893 posts
  • 554 Pinsiders participating
  • Latest reply 7 hours ago by hawkfanz
  • Topic is favorited by 265 Pinsiders
There have been 1,702 images uploaded to this topic. (View topic image gallery).
26 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8893 posts in this topic. You are on page 155 of 178.
#7701 10 months ago
Quoted from Mr_Tantrum:
Has anyone done any custom coin reject inserts for this game yet? That will definitely be something on my "to do" list as I don't like the generic ones that come with the game. They look like someone is turning up the volume to me instead of inserting a coin. Seriously, who holds a coin like that when they are about to insert it into a game? Also, looks like a woman's hand with well manicured fingernails. Not that I have anything against women, but just not representative of the vast majority of middle-aged men pinball enthusiasts of whom I imagine mostly have unkept nails (I've seen enough of my share of close-up pics and vids on Pinside to be highly confident in my assertion).
I'd probably go with Martian heads (either b&w outline or maybe even a color image would work with these).
My coin inserts are custom and very similar to what was posted above
#7702 10 months ago
I still need to design a mounting bracket for the LEDs, but overall the illuminated flipper buttons were a fairly simple mod. Of course I had to order all of the parts and make my own wiring harness to tap into the LED speaker connector, but everything went smoothly.[quoted image]
Looks great! I'd be in for the top sticker and flipper button mods.
#7703 10 months ago
In the manual, but outlined in this post: https://pinside.com/pinball/forum/topic/attack-from-mars-remake-afmr-owners-club/page/27#post-4095492
You just need a microSD card to transfer the file.
RM
#7704 10 months ago
We’ve done under cab lights in similar fashion.
https://lermods.com/shop?olsPage=products%2Fattack-from-mars-remake-pinball-led-strip-undercabinet-light-kit
#7705 10 months ago
Finished the flipper button LED mount designs (different for left & right). Now I just need to print and test for fit. FYI, these will be adhered to the inside of the cabinet using the same high-tack double-sided adhesive I use for all of my decals. I wanted to avoid adding screw holes to the cab if possible, so I'll have to see how things workout.
#7706 10 months ago
Yes, I know, and this is a great mod you've put together. Under cab lighting is not for me (at least for now), but I used the same principles I learned from reading the informative posts here about how you guys did it to design and integrate my flipper buttons. While I had to build a couple of custom cables, everything else was off the shelf LED cables and connectors.
#7707 10 months ago
Quoted from hawknole:
I like them. Nice job.
#7708 10 months ago
For the drop target I decided to go nuclear, and I'm really happy with how it came out.
#7709 10 months ago
I anyone is interested in purchasing any of the decals, please PM me. Pricing including US shipping is as follows:
- Target bank top decal | $6
- Drop target decal | $5
- 3 Bank target decals | $12
The full set of decals ordered together | $20 (save $3)
All decals are printed on a photo quality printer using only OEM inks and ultra gloss OEM paper. I coat them with a clear gloss vinyl, precision cut, and color edges on the drop target and target bank top decals. For adhesion I use a high tack double-sided sheet that covers the entire decal, and on the drop targets I use a shock absorbing clear mounting tape that does not require the center be punched out for the target rivet.
FYI, installing the drop target can be a challenge, but here is how I did it (takes a little work, but makes install a snap).
1) Turn on the game and start if required to bring the drop target in the up position. Turn the game back off.
2) Fully pull out the playfield and rest on lockbar support.
3) From backside of backboard removed the two screws holding in the mothership assembly.
4) Set mothership assembly aside to where you can easily access the drop target.
5) The drop target is very sensitive, so do not touch it from the front side. Remove the decal backing, use one hand to push forward from the backside of the drop target, and apply the decal evenly with the other hand (should be flush with top and both sides).
6) Reposition mothership assembly then insert and tighten the two screws.
When installing the top target bank decal, do so when the assembly is in the lowered position (you will need to press decal firmly into place, so lower position is better.
#7710 10 months ago
Just finished installing my flipper button LEDs using my custom brackets. Very clean install, and the brackets worked as I had hoped.
IMG_2984 (resized).JPGIMG_2989 (resized).JPGIMG_2987 (resized).JPGIMG_2990 (resized).JPG
#7711 10 months ago
Nice idea. Just a "holder" for the LED strip, right? Any pics from outside the cabinet?
#7712 10 months ago
Quoted from markp99:
Yes, just a holder for the strip without doing anything permanent to the cabinet. I meant to post external pics, but must have somehow messed up. I can take some more later, but here is my previous post that shows the overall results when I was testing.
https://pinside.com/pinball/forum/topic/attack-from-mars-remake-afmr-owners-club/page/154#post-5292016
I probably spent more than is reasonable just to illuminate the buttons (wouldn't be the first time I did such a thing on a pinball machine), but I like them. Here in the next day or two I'm going to calculate what everything costs, and if there is enough interest (I'd probably need at least 5 orders) then I'll sell full plug-and-play kits that include everything.
#7713 10 months ago
Quoted from Rascal_H:
Those Martians look great! I need to do this!
I can lead a horse to water . . .
amazon.com link »
#7714 10 months ago
My "Duct Tape Solution" (tm) would be much less elegant than this one!
I might have some interest in a kit for this.
Actually, I have a bunch of RGB LED boards left over from my GoT project. I bet a simple bracket might suffice to hang this near the flipper buttons. Might not be bright enough, but worth a try.
#7715 10 months ago
I must say, for a sci-fi movie from 1956, it really held up IMO. The SFX had to be incredibly advanced for the time as they were extremely well executed. The one thing that was kind of funny is that space travel was in a flying saucer very similarly shaped to the AFM versions. They even had a scene where they were coming out of lightspeed travel and they put themselves in a process that looked very similar to the transporter of Star Trek. I wasn't quite sure what was going on here, they defiantly weren't transporting, but this had to definitely influence that element of the Star Trek TV show.
The ship was decelerating to sub-light speed, therefore:
"A variation of the classic transporter beam was employed in the ship's D.C. (deceleration) stations to protect the spacecraft's occupants from the worst effects of decelerating out of hyperspace and back into real-space. This feature was later internalized in the newer starships which used warp drive nacelles, thus making the point where the actual jump in or out of warp space or hyperspace virtually unnoticeable."
Lot of interesting reading about Forbidden Planet here:
http://www.pjfarmer.com/secret/contributors/forbiddenplanet.htm
#7716 10 months ago
So I have a switch error on AMFr and noticed switches 48, 71 and 72 are all not registering. Test comes up as(CHECK SWITCH 48 RIGHT TOP LANE). They all seem to share the same black wire. Not seeing any breaks along any of the wires either. I have continuity from all three on the black wire back to the plug at the furthest left position on J8. CGC support has gone silent on me for almost a week. Any ideas how to narrow down what the issue is?
#7717 10 months ago
I'd be happy to sell the brackets separate on their own for $10 including US shipping. They are 3D printed in black with adhesive backing covering the entire surface for attaching to the interior of the cabinet. I'll even add a hole in the center bracket handle in case someone wants to screw them into place. Anyone can PM me if interested in purchasing.
#7718 10 months ago
Quoted from jibmums:
Very cool (in a sci-fi nerdy kind of way). Thanks for the link.
#7719 10 months ago
So, after evaluating everything, I'm offering my interactive illuminated flipper mod kit for $50 including US shipping. I will want a minimum of 5 commitments before I'm willing to take orders (I have to buy many of the items in bulk to make the kit). After the initial 5, I will need commitments in increments of 5 to fulfill subsequent orders. Please reply to this post if you are in, and if we hit at least 5 by the end of the weekend then payment will be required and I'll begin production.
Kit will include everything you need to illuminate both flipper buttons and will interact with the speaker lights:
- Power splitter to tap into speaker lighting
- Cabling from the backbox to the cabinet
- Splitter in cabinet to left & right extension cables
- 2x Extension cables
- 2x Interface to LED strips
- 2x LED strips (3 SMD each)
- 2x 3D printed LED strip adhesive mounts
- 2x Transparent flipper buttons with springs
I will also create step-by-step directions for installation. There will be no modification of the pin or its wiring required.
#7720 10 months ago
I will also create step-by-step directions for installation. There will be no modification of the pin or its wiring required.[quoted image]
I'm in!
Rob
#7721 10 months ago
I’d like a set
#7722 10 months ago
That's 10+ commits for the flipper button mod thus far.
rrosenhouse
Vyzer2
Chappie101
wolftownjeff
Monte_
Bentleybear
mjannusch (maybe 2 if works with MBr)
Tilted81 (maybe 2)
Wolftownjeff (maybe 2)
#7723 10 months ago
That's 3 commits for the flipper button mod thus far.
rrosenhouse
Vyzer2
Chappie101
& wolftownjeff
#7724 10 months ago
Any idea if these will work for MBr too?
#7725 10 months ago
I'm in as well for at least one set. 2 sets if it'll work in MBrLE also (which I'd think it would).
#7726 10 months ago
Quoted from mjannusch:
Good question. Can someone take some close-ups of the following in MBr for me?
- The LED connection to the speaker (remove the backglass and lower the speaker panel. You should see a 4 wire connector (square shaped if viewed from end) somewhere near the left and/or right speaker with red/gree/blue and a yellow or black wire probably). Connectors will look like the photo below.
- An inside shot of each of the button areas like I posted here: https://pinside.com/pinball/forum/topic/attack-from-mars-remake-afmr-owners-club/page/155#post-5293448
#7727 10 months ago
Here ya go! Also, IN!!
94F7CA36-51C8-4E2C-8FBB-486D0C645D91 (resized).jpeg9EB731C9-F514-4922-B1A7-BC263F3A4B0E (resized).jpeg
#7728 10 months ago
Can you show a pic of your connection at the speakers? We run our undercab lights through that connection, plug and play, and I just want to make sure there won’t be any compatibility issues so people don’t have to worry about it if they have our kit already (or have yours and want ours). If you made your connections like we made ours, anyone who buys your flipper buttons will not have to worry about compatibility with our undercab lights. And yes, the connection is the same for MBR. You must have an SE or an LE for these to work.
Our undercab and instructions can be found here:
#7729 10 months ago
I am in!
#7730 10 months ago
Quoted from Lermods:
All I do is use a Y cable with the same 4 pin connectors to feed off of the RGB +12V. I don’t see any reason why both wouldn’t be compatible. Mine could just Y off your Y, or even Y off the other speaker.
Better yet, for those who already have your mod, I could offer a 3 way splitter that would replace yours and my two way ones. That way they would only need one splitter but it would feed both mods.
I can try to get a pic up tomorrow.
#7731 10 months ago
Okay, I’ve been getting lots of PMs and things are getting hectic (I never thought the mod would be so popular). So, I’m definitely going to do a first run. I think I’ll give everyone a chance to commit through Sunday, so I can order all the materials on Monday. I’ll be PMing everyone over the next couple of days to provide payment info.
After seeing the pics for MBr, my mod will also work for it. I’ve also had a question about working with MMR. Are there any MMR owners out there who can confirm that the connections are the same (pics would be great)?
#7732 10 months ago
Set me up for 1.
#7733 10 months ago
Mmr does not have speaker lights that are stock with the game.
#7734 10 months ago
Does it have any RGB line you can tap into?
#7736 10 months ago
MMR might be doable with the new rgb lighting and panel upgrade kits coming out.
#7737 10 months ago
Quoted from YZRider926:
If a MMR was equipped with the RGB lighting as the other CGC pins are, I’m sure they would use the same wiring and both my nod and the under cab lights should have no issues connecting. It sounds like the MMr RE will have standard, but I’m still unclear if there will be a full RGB retrofit offered, and if so when it will be released.
#7738 10 months ago
Quoted from BentleyBear:
Set me up for 1.
On the list. FYI, please PM me with your address and I can provide an accurate shipping quote.
#7739 10 months ago
Sounds like every MMR will be able to be updated to what the RE is going to have.
#7740 10 months ago
Here you go. Pic of current splitter with potential add-on male lead to power both buttons & undercab, along with pic with everything tucked in place.
BTW, not only do I crimp my wire leads, but I also solder and test them to ensure 100% they work and will not fail.
#7741 10 months ago
How long of LED strips do most people use for undercabinet lighting? 10SMD, or...20SMD+?
Huh...I would have thought comet pinball would have rgb led strips...but I can't find them there. Do we have to go to Ebay or something to find them?
#7742 10 months ago
Quoted from Gogdog:
I can't speak to the length, but if you want a full DIY and not the plug-and-play kit from Lermods or the flipper button kit I'm offering, then these will do the trick: amazon.com link »
If you don't want the brightness of the 5050 SMDs, then you could go with a 2835 SMD strip or something in between.
#7743 10 months ago
[quoted image][quoted image]
I don't think you need to make that extra lead for undercab. Your connections will work fine with my undercab, no issues.
Quoted from Gogdog:
We use 4 feet for undercab lighting and use the 5050, 2835 is too dim IMO.
#7744 10 months ago
Ah nice...learn something new every day. Ok, so with those strips, you cut in 3 smd sections (so 3, 6, 9, etc), and then solder the wires directly to the strips at the 4 connection points.
Though...the led strips I was buying from comet are usually 6.3V, and these are 12V (though comet does sell 12V versions as well). I guess the speaker lights in AFMr are running 12V that you are tapping into, vs the GI lights (that I tapped into to run a trough light) are 6.3V?
#7745 10 months ago
Quoted from Gogdog:
Yes those strips can be cut in multiples of 3. Yes, RGB lighting is 12V in the game. You can either solder or use connectors.
#7746 10 months ago
I don't think you need to make that extra lead for undercab. Your connections will work fine with my undercab.
Just an OCD thing for the buyer, do they want 2 splitters linked together or a single one.
#7747 10 months ago
I’m in. Thanks for the MBr crossover post
#7748 10 months ago
FYI, cutoff for first round of AFMr/MBr flipper button lighting kit will be this Sunday at 1:00 Central (must have paid by then). I'll be sending out PMs to everyone who has expressed interest thus far later today to everyone listed here, but please PM me if you want to order and aren't in the list below:
Dashmonster
rrosenhouse
Vyzer2
Chappie101
wolftownjeff
Monte_
Bentleybear
mjannusch
Tilted81
#7749 10 months ago
Thanks for the info...wow, I never would have thought 4' worth...I would have definitely made it way too short if I had just guessed. Though now that I think about it, it is a large area to illuminate (the entire bottom of the cabinet). I guess if 4' is too bright for my room, its easily cut after the fact anyway.
#7750 10 months ago
Dashmonster
rrosenhouse
Vyzer2
Chappie101
wolftownjeff
Monte_
Bentleybear
mjannusch
Tilted81
If it works on both AFMR LE and MBr LE l’ll take two
5,999
Milford, CT
$ 16.95
$ 249.00
