Quoted from markp99:AFMr - Drooping Drop Bank
Not a big deal, but the drooping drop bank on my new AFMr tweaks my OCD compulsion. It's leaning to the right...and it makes me crazy
The assembly has a good degree of slop allowing for this alignment issue; I can easily rock the assy left and right. There does not appear to be any stop or adjustment screws to improve this condition.
Any suggestions to address or minimize?
My OCD brain thanks you in advance.
If you figure something out, please let me know!
On a related topic, my drop bank stopped dropping. During normal play, it would register hits, but never drop.
It failed the startup test, as well as the motor test (test 19).
Motor test failing
Startup test report
I lifted the playfield and wiggled some stuff, and got it back for a while. Sadly it was only a temporary solution. Since I've got a fancy new warranty, I figured I'd open a ticket, not expecting that I would get a response before Monday morning. Whatever they're paying @LTG, it isn't enough. On a Sunday night, I got a response back about 10 minutes after submitting the ticket, suggesting I completely re-seat the connector for the down switch:
It's the lower connector in this picture:
One of the crimp connections to one of the sockets felt a bit loose compared to the other ones, but a full disconnect-and-reconnect seemed to do the trick.
If it happens again, I'll replace that crimp connection.
As always, a big "Thank You!" to Lloyd!
