(Topic ID: 192072)
Attack From Mars Remake (AFMr) Owners Club
By Pin_Guy
  • 9,735 posts
  • 634 Pinsiders participating
  • Latest reply 2 days ago by mozach
  • Topic is favorited by 290 Pinsiders
26 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 9,735 posts in this topic. You are on page 105 of 195.
#5201 3 years ago
Back to my diverter chattering or activating during slings or Flippers it might be a loose connection it might be the solenoid driver board I'll have to investigate it further but definitely it's the diverter moving while the slings are running something is amiss.
I guess it's possible that during the vibration of the slingshots in flippers running that diverter is losing power I'll have to investigate further.
#5202 3 years ago
Quoted from LTG:
Should be consistent. Go into CGC menu and turn the launch a little stronger, see if that helps.
Worked thanks
#5203 3 years ago
Quoted from ctozzi:
Look what just showed up
Very nice! Post a pic when it's out of the box too. Great game, love the green.
#5204 3 years ago
I am going to be joining the AFMr club on June 12. Very excited. But I purchased a Special Edition, not an LE. I guess I want some comforting words that I didn't mess up the purchase by getting the SE. I love how it plays do I am confident that all will be good but I have some concern from the ratings only rating the LE and almost everyone seems to have an LE and not a classic or SE.
#5205 3 years ago
Quoted from Atrain:
I have an SE and love it, no second thoughts. I'm not really into toppers and that's the main advantage.
I added some nice game lighting to the playfield and undercab lighting tied to the stock speaker lights and it looks and plays great.
#5206 3 years ago
Quoted from Atrain:
I have a classic and really enjoy it. I'm prob the minority but I just don't like how the super large screen looks compared to the original - at least not enough to justify getting it over the classic. If it was SE vs LE - it's all about that topper. It's very cool but I'm kind of over toppers now.
#5207 3 years ago
Quoted from pinballinreno:
Ball search starts in that area fast. I know after bricking several shots and hitting nothing it will start to open and close looking for a ball.
#5208 3 years ago
Quoted from Atrain:
I think the LE is worth the $700 price bump from the SE, but that doesn’t make the SE bad by any stretch. I wouldn’t say the same dropping from an SE to CE since I think the larger display is a great feature.
#5209 3 years ago
All my solonoids are dead, any suggestions?
Game starts up.
Shaker works.
Running 2.0.
#5210 3 years ago
Quoted from Atrain:
The SE is awesome, you aren't going to regret that. My LE was only like $500 more and I got it for the topper and green trim which I really wanted, but the SE comes with the giant color screen which I feel is the biggest draw.
#5211 3 years ago
Quoted from SMI3:
Game starts up.
Shaker works.
Running 2.0.
Try open the door, there is a metal bit attached to the door by the hinge that pushes the solenoid isolation switch in when the door shuts. It cuts off the solenoids for your protection when the door is open. Try bending it a bit towards the white button switch to ensure it is pushing that switch in enough. That happened to mine just suddenly. It must have been bent just enough to work then maybe the game got shifted with a bump.
#5212 3 years ago
Here is your pictures Chill, I’m very happy with the quality and fit and finish Chicago has done on these games after owning both originals of AFM and MM. I’m not one for toppers but this one is just fantastic. I’m waiting for a response from them on the 2.0 Pic chip as mine shipped with 1.0.
#5213 3 years ago
so you went MM and AFM. Was thinking about this recently with them technically having a lot of similarities. Interested to hear your thoughts on that after having some time to play with AFM.
#5214 3 years ago
Quoted from Atrain:
I have an SE and love it. No regrets about not getting an LE. Same gameplay, sound, display, and shaker. Awesome!
#5215 3 years ago
Quoted from Plunger069:
I also have an SE and love it. You will be very happy!
#5216 3 years ago
Quoted from Only_Pinball:
Ditto here, but if a used topper were to show up on the secondary market, I would probably jump on it.
#5217 3 years ago
Hi. Finally set up my LE. Can anyone help me with the connections to the topper? I seem to have a 3/4 female that must go to the set of males above the blank inputs on the board except the male is 4/4. Any help with this all all other connections (though I seem confident with the rest) would be appreciated. I’m including a pic of my board that has what I think is an extra pin. Thanks guys.
#5218 3 years ago
Quoted from Saveleaningtower:
You can either remove the pin from the board, or remove the plastic plug from the connector. I went with the latter.
Marc
#5219 3 years ago
The wires are labeled, if yours shipped like mine with white pins in the harness, remove them with your fingernail and then plug them in. Let me know if you need a picture, but all the cables are labeled as is the pcb board.
#5220 3 years ago
See my picture. Cut pin off of the board or remove the plug from connector.
#5221 3 years ago
I can’t believe this has not been taken care of at the factory yet. This oversight was noticed after the first batch. How can they still not have build instructions to snip off that pin? They have built at least 1000 of these since they new what their mistake was, but the newer customers still have to deal with it.
Edit: well probably at least 750 of them since this board is only on the LE.
#5222 3 years ago
Thanks guys. I appreciate the multiple responses so quickly. I didn’t want to fry anything so Kashani and I thought it would be better to leave it alone till we were sure. I will probably opt to pull the plastic plug and just connect 4 to 4. Seems like either way doesn’t matter. I’m happy that I can finally see this topper in action. You guys rule!!
#5223 3 years ago
Cutting off the pin is the correct way to go, It protects against plugging it in backwards down the road.
#5224 3 years ago
Good point. Thanks. I will go that route
#5225 3 years ago
Hello, does anyone know if I can buy an AFMR LE Topper and put it on my AFMR SE? Thanks
#5226 3 years ago
Quoted from Jimmyhonda:
Go into your CGC menu and see if the topper software is in there. If so then all you need is the topper and small board for the head and harnesses.
#5227 3 years ago
Quoted from LTG:
Good point. If you manage to find a topper for sale on the secondary market, make sure to get the topper board as well, since it's not in the plywood box the topper comes in, it's bolted into the backbox.
#5228 3 years ago
I'm thinking about getting a SE, are there earlier build dates that have had problems. Should I be looking one after a certain date?
#5229 3 years ago
Quoted from Ramjet:
They are all the same.
#5230 3 years ago
so the only hiccup I keep on having is that on ball launch when I want it to go all the way around, sometimes the ball gets caught in the bumpers. It's not 100% going around. I tried to make the power higher and it appeared to work but still getting that issue. Anything I should look out for?
#5231 3 years ago
Quoted from delt31:
Open a ticket with CGC. There is a fix they can help you with.
#5232 3 years ago
Quoted from pintechev:
ok thanks
#5233 3 years ago
Diverter chattering caused by loose connection so its fixed YAY!
Now something odd.
Mothership while being blown up causes right or left sling to activate?
I have the slings gapped pretty wide (for slings...) at this point and it still does it once in awhile.
The pops dont activate and I have them set closer than a hairs width.
Sling does not activate by firmly slapping the playfield.
I went through and reseated all of the connectors under the PF.
I reseated all of the plugs on the PC boards....
Has anyone else seen this happen? Or, is it supposed to happen? It would be a cool effect to blow up the slings when you kill the ship.
Let me know.
#5234 3 years ago
Any news on Doug leaving CGC and going to Stern?
#5235 3 years ago
Quoted from Arcade:
A thread on Pinside, Pinball News, and TWIP
#5236 3 years ago
Quoted from LTG:
Thanks. Read TWIPs last post and it has no info at all other then it may happen.
Looks like pinball news and Pinside for the win.
Now we just need CGC's response.
#5237 3 years ago
just an FYI, I put a trouble ticket in for a relatively minor issue and I had a formal response and solution within 24 hours - part being sent in the mail. Done. Amazing customer service.
#5238 3 years ago
its obviously true given there is a press release! or its some funny shit late April fool.
Will be important to see who in CGC picks up from where Doug left as he was the main contact for CGC in pinball really.
Hopefully good news for us outside of the US from a Stern point of view. Pricing from Stern on international markets has been bizarre especially here in the UK.
Neil.
#5239 3 years ago
Quoted from NeilMcRae:
I'm confident Doug will leave that in good hands.
#5240 3 years ago
Quoted from LTG:
Doug had promised a few people that he would have something in writing regarding the playfield warranty extension. I guess that is never going to happen now.
Never expected it would, seeing that it has been 6 months since he told me this over the phone, but this sort of seals it.
I've now had really amazing experiences with JJP and Stern, and I'll be putting my money into their pockets going forward.
IMO, the only good thing that CGC has going for them, is LTG
They'd be lost without you, sir
#5241 3 years ago
Quoted from Damien:
You can certainly spend your money how you wish, but CGC is more than just Doug Skor. You should reach out to Doug Duba (also on Pinside) about the written warranty extension.
#5242 3 years ago
Just put out an SE at Ale Asylum in Madison WI! Happy to be in the club!
#5243 3 years ago
Just noticed today some scratches on the mirror blades on the left side, Im so sad! I dont even know how they got there, I never lifted the playfield. the only thing I did recently was I put some felt tape around the edges of the glass because it was rattling. Man! I wonder if the ball hit that area cause that.. anyone have any scratches too?
#5244 3 years ago
Quoted from Oneangrymo:
That’s why I hate all blades, look like shit after a while. I wish there would have been an option to not get the blades on the LE.
#5245 3 years ago
Quoted from WackyBrakke:
It looked awesome brand new, wonder if maybe down the road I can just remove them.
#5246 3 years ago
They are glued to the cabinet, so if you remove them then your cabinet looks like shit. I really hate whoever invented these stupid things. HATE
#5247 3 years ago
Thats dumb, how come they just arent bolted in so they can easily be removed. I hate stupid glue.
#5248 3 years ago
YUP side blades are the fucking worst thing ever. HATE EM
#5249 3 years ago
Just looked and I actually have some on my left side as well, in about the middle of the blade...
#5250 3 years ago
We have powerblades (the animated ones with the UFO beams that light up) and they still look great. I'd never have mirrorblades, though.
