IMG_6208 (resized).JPGI was lucky enough to pick up an Attack From Mars while on vacation at New Year's, I was in the right place at the right time. The machine plays great and is "good from afar" as they say. It was in a guy's personal collection for 15+ years and is due for a good make-over. I got it with a NIB Mirco playfield as well so I will eventually be doing a full playfield swap. I'm not sure if that will be this winter or next but I am excited to try.
Yay!
This thread will be a bit of a slow burn as I pick away at this project. I am dying to play the game so my restoration will probably be in bits and pieces until I get to the big stuff like the playfield. I will state up front that everthing I know about pinball machine maintenance has been from these forums supplemented by my impulsive nature so if anyone sees me doing something stupid, PLEASE TELL ME! I will probably be asking more questions along the way than providing any to others so I appreciate all the help in advance!
First problem, half the lighting is out in the backbox, culprit after a couple of days of messing around, some toasted connectors. It had me stumped because once I opened the circuit, I measured voltage at each critical point but when everything was connected, no current.
I replaced the obviously burned J106 first, still no luck.
Then I took a good luck at J103 and realized the wire in position 5 that looks black in the photo below is actually supposed to be white. Mental note, never use black connector housings.
Once that was replaced, all GI is now working.
Next up, the backbox tub.
Lots of busted sockets, duct tape, etc. Once I got the wiring off, it got a good cleaning in the bathtub but yikes, is it yellow.
Thanks to some advice from Christopher at High_End_Pins, I picked up a can of flat white Krylon Fusion and gave it a whirl. It's -20C out this morning so the garage is out of the question but luckily I have a friend who happens to love pinball with a detached wood shop that accommodated my stinky spray paint (thanks Rob).
I'm not much of a painter but it went on very easily in one coat.
The final result blew me away - it looks perfect.
The translite is also pretty dingy (and signed by Brian Eddy and Doug Watson) so I think it deserves to be clean.
I tried scrubbing gently with Dawn which got off most of the black dirt and then after testing Windex successfully on the edge, I used that for a final cleaning.
Now if my shipments from the US would hurry up I can get it reassembled.
Meanwhile I am replacing all the playfield GI with LEDs so need to remove all the ramps etc.
I don't think anyone has been under here in awhile.
Some Novus, elbow grease and I figured I'd try to underlit LED rings, and wow, they are bright. Hopefully not too overpowering once the ramps are back in. We'll see.
I couldn't resist buying a vibratory tumbler after hand-polishing the playfield support brackets and almost getting carpal tunnel.
$70 Canadian at Princess Auto (our version of Harbour Freight). I figured I'd try it out on the sling mechanisms first so walnut shells and a healthy squirt of Novus 2 and let 'er rip for the night.
I'm pretty happy with the result. I am just going to start working my way through all the mechanisms, add molex connectors to them, then clean, polish and reinstall.
