(Topic ID: 157045)
attack from mars issue
By farroutt
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by ChrisHibler
#1 3 years ago
ok so my AFM has an issue. the driver board fried. so i installed a new board, which was simple. the game starts, plays, sound is great. my problem is that the DMD display board does light up. I have already taken the DMD out and installed it in another game and it works fine. changed out the ribbon cable. disconnected connectors and reconnected onto the boards.
i cant seem to find another audio/video board instock anywhere. any ideas as to what it might be? thank you in advance.
#2 3 years ago
Check the voltage coming into the DMD. It need very specific voltges to operate. Pinwiki has detailed information.
Marc
#3 3 years ago
Power to board? Fuses on board present?
#4 3 years ago
board has power, light is flashing on board. LED501 is labeled above it
#5 3 years ago
also, all fuses have been check thoroughly.
#6 3 years ago
did you put the ribbon cables back correctly. Make sure the red line goes on pin 1-2 on the Display driver board.
#7 3 years ago
Quoted from pintechev:
Marc
You need to do this. DMDs only operate with specific voltage. There are three key readings and a voltage difference between two of them that must be maintained.
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Testing_DMD_Controller_Power
#8 3 years ago
Once you've tested the HV you may need to rebuild that section. If you need help, LMK and I can take care of it.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
PinWoofer
