(Topic ID: 255391)
Atlantis Motor Timing/Scoring Issue
By izzicat
4 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 4 months ago by izzicat
#1 4 months ago
I'm in the middle of bringing an old Gottlieb Atlantis back to life. It's been sitting unused for almost 30 years. Most of my issues have been resolved with just a good batch of contact cleaning and adjusting. I'm fortunate enough to have what appears to be a complete set of documentation.
My latest issue is that every score event that is a multiple of 5 (like 500 points or 5000 points) only gives me 4 (400 or 4000). The chimes are in sync with the points. Four chimes, for point increments, NOT 5. From what I can tell, the motor position that stops the rotation of the motor (2B), seems to engage before position 1A has completed counting the 5th notch. This happens no matter which of the three revolution segments I'm in. 2B engages before the 5th notch in 1A, so relays C and D drop out before the last count.
I looked real hard at the 2B bank of switches, and there appears to be no adjustment. Actually, it looks like a piece of the "wiper" may be broken off. Makes some sense, as if the wiper was longer it would rise off the post a bit later in the arc, which would give 1A a little more time to engage. But I took it apart and the end of the wiper is square, so if it is broken off its a clean break.
BUT, I also looked at the wiper on the 1A switch. I figured it was possible that 2B may not be coming in too early, 1B may just be running a bit late... There was a little "slop" in the play on the wiper arm, which by the way is in the "S" position. So I figured if I could bend the wiper just a bit, I could get it to climb over the gear before 2B engaged.
Guess those things aren't meant to bend, as I broke it. .....
So now I'm on the hunt for a replacement S/L wiper arm (I may have a source).
But my real question is "am I missing something here"? Can you come up with a reason why 2B is actually meant to engage before the 5th iteration of 1A? Is something else going on?
I can post some pictures, but I figured that there are a lot of you that Atlantis schematics laying around.
Thanks in advance....
izzicat
#2 4 months ago
Well done on your diagnosis so far.
Quoted from izzicat:
When a 500 or 5000 point target is hit it fires the C or D relay. After the momentary pulse from the target switch the C or D relay holds itself on until the normally closed Score Motor 2B switch opens which shouldn't be until after the 5 pulses from the 1A switches. The Score Motor should keep itself running past the 2B switch pulse until the switch at 1C opens.
So the sequence would be:
- Target switch closes
- C or D relay fires
- Score Motor starts
- 5 pulses generated as the 1A switch closes
- C or D relay relaxes when the 2B switch opens
- Score Motor stops when the 1C switch opens
If one or more of your Score Motor cam followers are damaged that could mess up the sequence.
/Mark
#3 4 months ago
Mark, Thanks for the help. I have a donor Gottlieb Wild Life play field {no head} that I bought decades ago for parts. I believe it is a close enough vintage to the Atlantis that I can use the score motor parts from it as reference and replacement. It's in storage, so hopefully I can get to it by the weekend. (snowing here in Missouri tonight).
I do have a few other issues with the Atlantis, but this one is the annoying one. Pretty sure the problem is the end of the follower {wiper} arm on 2B is broken off and has had a "field modification" which shortened it about 1/4" and it is engaging too soon. It's not in a part of the 2B switch cluster impacted by the S/L position... Now if I just hadn't broken that follower arm on 1A ...
izzicat
1,975
$ 89.00
Pappy's Pinball Palace
Cabinet - (Alt) Translites
Maple Street Sign Shop
$ 40.00
Arcade Arts
$ 7,299.00
Arizona Pinball
$ 25.50
$ 40.00
Arcade Arts
$ 625.00
$ 2.50
Doc's Pinball Shop
$ 24.99
Lee's Parts
$ 49.00
Pinball Photos
$ 54.99
$ 125.00
Sparky Pinball
$ 4.49
$ 134.95
Hookedonpinball.com
$ 66.95
