My best guess is something in the Cherry D44Y lever microswitch family.
Here's a datasheet. I'm not sure if there's an actuator on the list that will match or not.
https://www.mouser.com/datasheet/2/71/Cherry%20Electrical_D4%20Series-492956.pdf
Also, if you remove the switch from the bracket, it might have a model number on the side that's hidden.
Forceflow is bang on.
You can replace it with a NORMAL OPEN cherry switch and bend the arm up like that to fit into that out hole. You can also use a 3 prong nc/no switch.
Any cherry from an old oystick should do it.
I've found d this to be an acceptable replacement for many of the Atari switches: https://www.pinballlife.com/switch-5647-12133-08.html
Quoted from semicolin:I've found d this to be an acceptable replacement for many of the Atari switches: https://www.pinballlife.com/switch-5647-12133-08.html
Have you used these for roll over switches? Is the action light enough? Thanks.
This page was printed from https://pinside.com/pinball/forum/topic/atari-switch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
