Went to look at a Superman pinball machine and the owner said they had sent all the boards to Johns Jukes for repair and they were repaired and tested before being shipped back. Here is the issue now, the left flipper will work but the right flipper will not (the switches are burnt and looks like it needs a new resistor as well) no other solenoids on the playfield are working, but they do score when hit. It also seems as if there is a switch stuck closed somewhere on the playfield because you can bump the playfield and it will score random points, 100, 500, 1000, etc. I have checked all of the fuses in the backbox with a meter and they all checked good. I also noticed that when I engage the outhole kicker, top left saucer and the drop target switches, the LED on the bottom left of the I/O board will flash. Any ideas on what I should check next?
