yeah the backglass is just some regular AC light bulbs. If i remember a little smaller but still just like household type lights.
Quoted from xsirxx:CNKay, question on the LEDs... I unplug my cabinet every night, do the LEDs work? they just wont go off when the machine goes off?
i am not following you. No need to unplug cabinet every night. that is what the power switch under cabinet by the coin door is for.
it is my understanding that Atari always trying to be innovative and do things the best, thought that lamps that were cycled on and off constantly like in attract mode would shorten a lamps life. So they designed there system with operator repair/service in mind. They are actually keeping the voltage on the lamp but just not enough that you can see the lamp on,(actually you can in a few unchoice places), but this warming voltage is plenty to turn an LED on, as most turn ON no problem at 1.2V. So if you put in an LED in any socket it will just stay on all the time. Atari also used the quick spade disconnects on every single coil connection. Another plus for servicing a coil or flipper as no soldering required. I have never had any trouble with those connectors, and they are nice each with plastic boot over them and much neater looking(i have seen some very scary three wire to coil lug connections as it is not the easiest thing with only two hands).
Notice the COPPER paint in the cabinet it is somewhat conductive like a Faraday cage or for ESD protection(10M to gnd). For the day, really ahead of the competition but bad timing for starting to produce pins as video popularity much bigger. And operators just not up to speed on the high tech new design so as soon as it broke, many just sat.
Another reason you can find them in real nice shape and cheap.
