(Topic ID: 280201)
atari pinball voltages
By dobo
1 year ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by dobo
#1 1 year ago
I'm having trouble getting the right voltages at the display and credit. I get my -90V but I'm only getting +47V. I disconnect J19(credit) and get the same readings testing the display. Then I disconnect J17(display) and then get -90V and +61V. With that the credit display will work and is bright. But then I need to disconnect both and measure at the PCB. Where are test point on that board? How do I test the PCB voltages. I just got the board back from getting fixed and I'm just not sure. I know I'm losing Voltage with the display because if I disconnect the display I can get the credit to work. I'm just not sure how to test the PCB. Can someone help me? I need to check the outputs on the PCB. And then after that how do I trouble shoot the PCB or the display?
#2 1 year ago
Quoted from dobo:
I'd check the square molex connector that connects to the light board/displays. Ohm out each wire to where it goes to the connector at the bottom of the PCB.
#3 1 year ago
How do I check 90v through out the whole machine? Aux board, transformer, and such.
1,300 (OBO)
West Point, UT
$ 22.95
$ 259.99
Great pinball charity
Pinball Edu
