I was trying to track down some lighting issues (in test 1 mode) and I noticed the dreadful smell of "hot electronics". I busted out the IR thermometer and found that several components on my Processor PCB were very hot. Specifically, three board components were reading hot:
1) C17 (0.1uf 25V ceramic disc capacitor) reading 500F+
2) CR1 (Diode, Transient Supp. P6KE18) reading 250F+
3) C1 (tantalum, 1uf 35V axial capacitor) reading 250F+
I assumed that those are not normal operating temps, so I need to replace something. I just don't know what to replace, and what order to start replacing things.
I checked the fuses on the Power Supply Assembly (F1-F6), all are good and properly rated for their position.
If you look at the schematics from the manual, it appears that all three of these components are directly "downstream" from J9, which provides logic power and logic ground (see image below).
Guesswork:
1) J9 sending too much power to the board. But wouldn't a fuse blow?
2) Improperly fused. But I checked the fuses and they are right.
3) Bad component. But which one? And which do I start with?
If these components were easy to find, I would just replace them all. But, I'm having trouble finding the correct components. And, maybe it isn't any of the "hot" components that are causing the problem (though they may all be damaged by now and should be replaced anyways), so I'm not sure what else I should inspect / replace.
There is a resistor, R1 (4 OHM, 10W) in the circuit, so maybe that is the failing part allowing too much energy through to the components?. I don't know if that is reasonable - not an electronics whiz.
Any suggestions would be appreciated. Note: The machine works and plays without issue, but I'm thinking that the temps of these components is not normal so this is hopefully a preventative repair.
