does anyone have a copy of the leon atari 1st gen test rom and the documentation to go with it?
the link for it doesn't seem to work
http://www.pinballeon.com/atari2/atae2.htm
i have had a Middle Earth machine dropped off for me to repair,
1st problem i had had was no clock, sorted that out,
now it fires most solenoids, and lamp outputs in rhythm with the reset going high low,
It will even do this with no cpu chip or roms installed.
I have programmed 2 new 2716 roms for it and done the mods to be able to use these roms, installed new sockets for cpu and roms.
I understand the reset will go high and low when the mpu program strays from its normal instruction sequence (quoting the atari trouble shooting book) and when the board is held in rest by holding in the reset button no lamps or solenoids are energized
i have repaired 100's of bally / Williams (all systems) sterns, sega, zaccaria and data east boards.
I will be following the instructions on the diagnostics flow chart tomorrow but if all fails i would like to have a test rom to help
