I am helping a friend restore a Bally Paragon. MPU is a new Weebly, new Xpin transformer board, recapped and rebuilt solenoid driver.
Everything was working OK until recently. Machine will not get into attract mode, and the mpu will not go past 6 flashes. No fuses are blown, under PF fuse is fine, f4 is fine.
So, I check things a bit deeper, and I unplug the sound board and start the machine, I get the 7th flash and the machine boots into attract mode.
What on this board could be causing the MPU not to get to the 7th flash? I did order the Big Daddy cap/component kit, but it won't arrive for a few days.
What should I be checking on the board that could be causing this?
Thanks in advance, mk
