New! Dark mode!
(Topic ID: 275793)
AS-2518-17 LED Locked on
By JethroP
68 days ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 61 days ago by JethroP
#1 68 days ago
Game was playing fine until the other day with it wouldn't boot. Observed the LED locked on at power up.
I assumed problem were the old brown sockets, so I replaced them, but that didn't correct the problem.
There is no corrosion on this board.
I removed all the chips except U6, U9, and U11. Also, replaced U9 and U11 with new chips from PBR and GPE. Still locked on.
The reset circuit appears to be working correctly per the tests in pinwiki.
I have continuity checked every pin on U6, U9, U10, and U11. Didn't find any problems.
I don't have another U6 to try, nor do I have another board to test the 9316-U6 in without changing jumpers. Is there a way to check the U6 any other way?
Troubleshooting recommendations?
#2 67 days ago
i bit the bullet and rejumpered a working board and tried my U6 chip in it. LED was locked on at power up, so I am concluding that ROM is bad. Unusual to have a ROM go bad? I guess I'll buy a new set and hope that solves the problem.
#3 67 days ago
Masked roms do go bad.
#4 67 days ago
Quoted from KenLayton:
Is this a masked rom?
#5 67 days ago
Yes.
You need to get a cheap eprom burner so you can verify roms on the boards you've been working on.
#6 67 days ago
Quoted from slochar:
Yes.
You mean I have to learn something new?
I researched them a while back and decided i didn't want to learn how to burn PROMs, and all that. Well, maybe it's time to rethink that.
#7 67 days ago
Certainly easier than sourcing them all the time - it's really not that hard to do.
Although.... some of the earlier oddball roms might need some finesse to read and verify, but in the cases of the era -17 and -35 you've been working with, most of the time you're just going to rejumper for a set of 2732 roms and just standardize on those (or 2716, which would be even easier because you can get new eeproms for those, no eraser needed!)
#8 67 days ago
So you are saying i can plug my original U6 ROM into the cheap eprom burner and it will verify the ROM is good?
#9 67 days ago
First you need to download the ROMs The Internet Pinball Database. Load the file into the buffer of the burner. Then verify.
It's easy - if I can do it I know you can.
Bob
#10 67 days ago
The 9316A chip i don't think is supported in many cheap burners. I don't see it listed in the GQ-4X or TOP3000 burner's software that I use.
https://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=info&page=9316.txt
pin: 2716 .......................9316
21 Vpp(high=read).........CS(active-low)
20 OE(active-low)...........CS(active low)
18 CE(active-low)...........CS(ACTIVE HIGH)
#11 67 days ago
Deleted. Got my answer in the PM.
#12 61 days ago
Going to mark this as resolved and start a new, more specific thread for continuation:
https://pinside.com/pinball/forum/topic/evel-knievel-won-t-boot
#13 61 days ago
Should not had created a new thread. Everyone loses the history of what was done.
#14 61 days ago
Quoted from PinballManiac40:
While some of the info in this thread was educational, it was general and didn't do anything to resolve my problem. The new thread describes my game and problem, and anyone reading it won't have to read historical postings to get up to speed. Hopefully
$ 11.00
Third Coast Pinball
$ 149.00
$ 159.00
$ 22.50
$ 149.95
Allteksystems
nvram.weebly.com
$ 86.95
$ 86.95
$ 119.95
Allteksystems
$ 9.00
Cabinet Parts
Third Coast Pinball
