(Topic ID: 228036)
Argosy spinner not alternating point value
By Sodacrack
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Sodacrack
#1 3 years ago
The spinner is supposed to alternate between 100 and 1,000 points as certain playfield features are activated. I think it is should switch back and fourth as the ball hits the slingshots, but may include other contacts. Currently the the value of the spinner only scores 100 points and the insert never lights for 1,000 points. Does anyone have any ideas on what to check?
I have cleaned and adjusted the "spinner lite" contact on the Change Relay, but it didn't make a difference.
Any help is appreciated.
Thanks,
#2 3 years ago
Well, is the spinner alternating relay actually switching positions on a 10 point hits?
If you manually close the relay with your finger, does the spinner lite?
Lots more to check out here before we can help.
#3 3 years ago
Check M/B sw. C here. And do you have a high quality scan of the schematic you can post (not phone pix)?
#4 3 years ago
Quoted from currieddog:
I have cleaned and adjusted all the contacts on the Change Relay. I will take a look at them again and work on getting the schematics.
#5 3 years ago
Quoted from CrazyLevi:
I will give it a try this evening and report back.
#6 3 years ago
The Change Relay(spinner alternating relay) does not switch positions on 10 point hits, but the spinner does lite when I manually close the relay.
#7 3 years ago
There is a small switch on the match unit that activates the change relay. You need to check that. I have the same switch on my Aztec, (it alternates the pops). I have to adjust it about once a year.
#8 3 years ago
PROBLEM SOLVED
The match unit was not functioning properly. The tab on the relay that moved the contact wheel needed to be adjusted. Thanks to all that helped.
