(Topic ID: 204888)
Are WPC Fliptronics 1 and Fliptronics 2 interchangeable?
By EvanDickson
1 year ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by Coyote
#1 1 year ago
I noticed that TAF is the only game with Fliptronics 1. I also noticed that TAFG has Fliptronics 2, but I didn't think there was a difference between the two besides custom ROM and gold highlights on the machine.
#2 1 year ago
Williams originals are not interchangeable.
Some of the reproduced fliptronics boards can be used in either if so marketed as such.
#3 1 year ago
Ok thks Lloyd. Seems like an odd choice for them to obsolete a cpu board after only 1 title. I wonder what was up with that.
#4 1 year ago
Quoted from EvanDickson:
Driver board changes ?
#5 1 year ago
Fliptronics 1 required a second daughter board and wiring. It's kind of a mess, and Fliptronics 2 is much cleaner, requiring only the one board.
#6 1 year ago
I have seen people mention that they converted TAF to fliptronics 2 but no one ever ponies up the info. Until they do I assume they are all just lying.
#7 1 year ago
Quoted from Syco54645:
It’s easy, just buy one of the rottendog replacement boards .. lol
#8 1 year ago
Quoted from Rdoyle1978:
No I have seen people say they use official WMS Fliptronics 2 boards in TAF.
#9 1 year ago
One post I've read mentioned that to replace a fliptronics 1 board with a fliptronics 2 board, you may need to replace the flipper leaf switches with opto boards.
TAFG does use opto boards for the flippers along with a fliptronics 2 board, so it does lend some credence to the theory.
I have not seen any details on what wiring changes that might need to be made. You would need to run additional wiring for the opto board electronics, at least.
#10 1 year ago
Quoted from ForceFlow:
Except games pop up all the time with leaf blade flipper switches. You just have to wire them right. And I believe some Getaways came that way.
#11 1 year ago
http://www.flippers.be/basics/101_wpc_intro.html Scroll down a little.
Fliptronics 1 relied on the relay on the driver board. Fliptronics 2 had it's own bridge rectifier.
#12 1 year ago
Quoted from LTG:
Yeah - Fliptronics 1 relied on power to the flippers being controlled from the power driver board - hence the relay on the PDBs. Fliptronics 2 had their own control on the fliptronics board.
PDBs with the relay will work in games that don't need it - you'll get a 'click' when flippers activate or deactivate, but the relay won't otherwise power anything. However, if you plug a power driver board that does NOT have a relay into a game that requires it, you'll never get flippers actuated.
So a Fliptronics 2 board will work in a Fliptronics 1 game, there's just a couple plugs that won't be used.
West Chicago, IL
KAHR.US Circuits
€ 3.70
$ 22.00
Yorktown Parts and Equip
