It’s fine to use.
It may not be as “slo-blo” as the original.
Always buy Buss brand fuses.
Pinball Life sells them.
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
Thank you for checking out the PinWiki - http://www.PinWiki.com/
The one with the thin wire looks like a fast blo fuse. Don't install a fast blo fuse where a slow blo fuse is called for or it can blow..well..fast.
Quoted from DarthPaul:Says slow blow on the packaging but to play it safe, I ordered some new ones.
Buy the Bussman brand from pinball Life in multiples of five as that is the quantity per metal tin. Makes it easier to organize them.
Quoted from DarthPaul:Says slow blow on the packaging...
Should also say slow-blow or "SB" on the fuse itself near the rating.
Quoted from sparky672:Should also say slow-blow or "SB" on the fuse itself near the rating.
Or "T" for time-lag, depending on manufacturer.
This page was printed from https://pinside.com/pinball/forum/topic/are-these-fuses-good and we tried optimising it for printing. Some page elements may have been deliberately hidden.
