New! Dark mode!
(Topic ID: 277775)
Are slings normally wired the same left and right?
By topkat
31 days ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 30 days ago by topkat
#1 31 days ago
I have a data east machine that has a right sling with a cap/resistor on the lower switch and the left has it on the upper.
The left doesnt register in test Mode But the right is fine. Before I change it to match I would like to know if that symmetry is a
Good rule?
#2 31 days ago
The switches on both sides are wired in parallel, so which switch the cap is on won't matter
#3 31 days ago
Thanks. Shoot. Then that isn’t why the switch doesn’t register
#4 31 days ago
Quoted from topkat:
Is it clean ? No broken wire from switch to switch to switch to board in the head ? Is it wired right. Compare the wires and components and lugs on the leaf blade switch to the working one.
Or post a good picture of both of them here for help.
#5 31 days ago
First two photos are the left sling. I removed the cap and resistor off the upper switch, but they had been there and test fine.
The wires look the same as the right except the left has an extra wire on one lug? The connectors to the board look good.
In game the sling does fire
#6 30 days ago
The switch that registers in switch test is the one that's mounted separately on the bracket, not the ones with the cap and resistor. That's the direct activation switch, which is why it works in game. Put the resistor and cap back on, that's there to give a solid pulse to the firing of the sling itself.
#7 30 days ago
Quoted from slochar:
Thanks. I will replace the components and check the switch on the bracket for a bad diode.
$ 54.99
Metal-Mods
$ 54.99
$ 54.99
$ 50.00
$ 21.00
Gweem's Mods
$ 7,999.99
Music City Pinball
$ 48.00
$ 7.95
Various Novelties
Pinball Wheezer
$ 22.00
Hardware
The MOD Couple
$ 14.95
$ 235.00
RS Technologies
Hardware
Filament Printing
$ 39.00
Concealed Art
