If I am not mistaken, the Score Reels are slightly different mechanically from the Jungle Era to the later Surf Champ error. Overall, everything is about the same, but they did change how they moved the zero/runout switches. The earlier ones use that bent metal wire part with the black sleeving. The later used a plastic rocker arm.
So, most of the major parts will be identical on the score reels but just in case you wanted to swap them over in their entirety, just be aware they are different (but functionally the same).
Most common part you will find broken will be the EOS switch on the score reels. It is very common to find one of the blades totally missing.
I think just about everything else in the head should be about the same.
If you are talking lower cabinet too, then there may be some differences there too. I can't remember if Surf Champ has the late model flipper assemblies (like on System 1 Gottlieb Solid State Games) as they were introduced near the end of making EM games. Jungle certainly has the old flipper design.
Surf Champ probably has a "Coin Unit" while Jungle used a large trip bank for players 2,3, and 4 enable.
