Hello, I'm trying to think of a way I could turn on all the machines in my arcade via motion sensor. Currently I have 10 games that are turned on by 2 surge protectors. Basically you have to squeeze between the games to flip on the 2 surge protectors. I was wondering about making it easier by connecting to a motion dectector so basically all you have to do is walk into the room and everything turns on.
My arcade is open to the public but I figure there are a lot of days of infrequent use, and I would like to save energy if the games aren't being played.
The closest thing I've found so far is this thing on amazon. It's almost perfect except I want a timer that lasts at least an hour before everything shuts back off. So far the timers on these things only go up to 20 mins.
https://www.amazon.com/Westek-MLC12BC-4-Indoor-Activated-Control/dp/B009KSECO8/ref=sr_1_11
The other challenge is the motion sensor needs to be a good distance away from the wall outlet so it can actually positioned to detect motion of someone walking into the gameroom.
I'm also hoping to not use a smart phone app to control it as I figure that will come with its own reliability challenges over time and make the solution more complicated than necessary.
Hoping someone has an idea on how to tackle this.
