(Topic ID: 118949)
Apron card protective material...Mylar?
By DnDPins
9 years ago
  • 6 posts
  • 6 Pinsiders participating
  • Latest reply 9 years ago by CraigC
    #1 9 years ago
    I have several older machines with original apron cards with a clear (yellowed now) material which I would like to replace. Is it mylar? What is the thickness?
    #2 9 years ago
    cut up a cheap clear report folder
    #3 9 years ago
    Cut up the screen protector that came with your HDTV or monitor, you probably have it rolled up in the box.
    Unlike the original material, the stuff never yellows.
    #4 9 years ago
    Do the right thing, not a bad hack.
    The material is called acetate, thickness for machines is 7 mils. You can get it from some office supply stores. Marco sells pre-cut sheets though: http://marcospecialties.com/control/keywordsearch?SEARCH_STRING=acetate
    #5 9 years ago
    Scotch peel and stick laminate.
    #6 9 years ago
    You can also get them laminated at Kinkos for a nice clear impossible to fingerprint solution.
    I've done this sandwitching metallic paper with instructions printed on acetate and then laminated. looks good with silver metallic paper on STTNG. I'll probably do ToM one of these days on a gold foil.
    -c
    This page was printed from https://pinside.com/pinball/forum/topic/apron-card-protective-materialmylar and we tried optimising it for printing. Some page elements may have been deliberately hidden.
