Quoted from balboarules:Ok, remove old decals, sand down head, apply primer, paint with oil based enamel, either buy rapid tac or make my own solution then apply decals.
Ok, remove old decals, sand down head, apply primer, sand, paint with oil based enamel, sand, either buy rapid tac or make my own solution then apply decals.
The wood grain will swell and raise slightly after the primer/paint is applied so you will need to sand it again with a finishing grit. The surface really needs to be smooth or any blemish will show through the decal. I usually do two coats of paint (sanding after each). I can't state this strongly enough the quality of the finished job will greatly depend on the prep work on the cabinet (sanding and painting).
On the black paint every game is slightly different, but semi-gloss black is typically a pretty good choice. With two coats you can always adjust the gloss on the second coat if you don't like it.
Remove the old decals using a heat gun and scraper or you will pull up a lot of wood and have to patch the area before proceeding.
