OK.I find some info about mesuring all type of transistor but it's different from pinballrepair.com tutorials,and now I'm confused because I always used thist tutorial
Or mabe these are another methods for test,need help
This I found
PNP transistors, left lead is base (i.e. - TIP36C and TIP42)
1. Put the DMM's black lead on the left leg of the transistor.
2. Test to the middle leg and the right leg with the red lead.
3. You should get a reading between .3 - .8 volts on each.
4. Put the red lead on the left leg of the transistor.
5. Test to the middle leg and the right leg with the black lead.
6. Your DMM should read open on each.
NPN transistors, left lead is base (i.e. - TIP102, TIP120, TIP121, TIP122, 2N6045 and SE9302 )*
1. Put the DMM's red lead on the left leg of the transistor*.
2. Test to the middle leg and the right leg with the black lead.
4. Put the black lead on the left leg of the transistor.
5. Test to the middle leg and the right leg with the red lead.
Testing FET/MOSFET
1. Black on source, red on gate: turns on the transistor.
2. Black on source, red on drain: low reading (.00X).
3. Red on source, black on gate: turns off transistor.
4. Black on source, red on drain: read open.
And this is from pinballrepairs.com
TIP122/102: Put the black lead of your DMM on the center lead or on the metal tab of the transistor. Put the red lead of your DMM on each of the two outside legs of the transistor one at a time. You should get a reading of .4 to .6 volts. Any other value, and the transistor is bad and will need to be replaced.
TIP36c: Put the red lead of your DMM on the center lead or on the metal tab of the transistor. Put the black lead of your DMM on each of the two outside legs of the transistor one at a time. You should get a reading of .4 to .6 volts. Any other value, and the transistor is bad and will need to be replaced.
TIP42: Put the black lead of the DMM on the base lead (as facing the transistor, the left leg) of the transistor. Put the red lead of the DMM on each of the two transistor legs (center and right), one at a time. The DMM should show a reading of .4 to .6 volts. Any other value, and the transistor is bad and will need to be replaced.
What can you tell me?
