(Topic ID: 293644)
Apollo 13 mylar original or not
By marschner
#1 3 years ago
I have an Apollo 13 which has Mylar pretty much covering most of the playfield.
It looks original but anyone knows if the game was shipped with this from the factory?
#2 3 years ago
Based on the machines I've seen, I would say no, it's not factory. If anywhere needed some mylar it would be at the top lanes where the ball drops, and I always see signs of wear there.
I know some earlier solid states sometimes came with mylar that was up to the purchaser to put on, but haven't heard about this on DMDs.
#3 3 years ago
HighVoltage
It just looks very original and fits around posts, slingshots etc. everywhere.
The lower playfield is covered by one large piece.
#4 3 years ago
I have various full mylar die cuts for some older playfields. Distributors had them and or you could request the factory.
#5 3 years ago
chad
So they were available as extras but not put on from factory?
It definately looks like full mylar especially made for A13 and is also perfectly put on the playfield.
I guess these full mylars are not available anymore?
#6 3 years ago
Quoted from marschner:
chad
Most likely all issued and used. It seemed that Data East/ Sega installed at the factory for the majority of production. On Williams, Bally it was hit or miss. Later Gottlieb Premier games all had a thicker factory set mylar.
#7 3 years ago
chad
I plan on putting on a playfield protector on but I don´t dare to take off the mylar, just wanted it nice and shiny under the protector.
#8 3 years ago
I had the factory mylar on an A13.
Removed it, no problem, using freeze spray.
#9 3 years ago
... but I don´t dare to take off the mylar, just wanted it nice and shiny under the protector.
You want it REAL shiny under there? Get thst damn mylar off
#10 3 years ago
Jjsmooth
Some say freeze some swear to heat. hmm??
#11 3 years ago
TheLaw
Yeah I know but since it´s factory put on I would rather leave it on, and also afraid of damaging the paint when removing.
#12 3 years ago
Jjsmooth
Modern games freeze spray works extremely well and quick. Never tried to heat one so csnt comment.
...and also afraid of damaging the paint when removing.
Games that late are all clear coated and should be fine.
Whilst you have it all apart I would really think aboot finding a hidden area to test freeze.
But i can tell you're a little skittish by the fact you are literally going to put 2 protecting layers on the machine.
#13 3 years ago
On High Speed, i tried both; heat and freeze.
Freeze worked MUCH better on that one.
#14 3 years ago
Quoted from PinballAir:
This is what scares people though. Machines of that era, eXpecially HS, are notoriously awful to do.
#15 3 years ago
I am sure my HS had the mylar put after it left the factory.
My Police Force definately had it from the factory.
On HS i lost some paint around the pops with heat. I stopped immediately.
I had all of the mylar off in 15 minutes by freezing it. No paint loss or insert print lost by freezing. YMMV
Getting the glue off, well, that sucked. Probably 2.5 hours plus, spread out over several nights.
Also, i am in HVAC/R so freezing things is much easier for me.
#16 3 years ago
I used freeze spray on my original STTNG playfield and the Mylar came right off. That being said, only the Mylar came off and it was clean...all the glue remained on the board. Folks swear by using alcohol and flower to turn the glue into a gummy sticky ball. I didn't bother to remove any of the glue as I only wanted to remove the Mylar to use as a pattern to cut new Mylar for my replacement playfield..
#17 3 years ago
Using flour on a Cleared PF?! New one to me
#18 3 years ago
I hear you all Freeze it is.
How did you remove the remaining glue then.
I have also never heard of flour for this.
#19 3 years ago
Quoted from Pin_Guy:
#20 3 years ago
Okay, but what IS the best way of removing the glue?
#21 3 years ago
When I removed my mylar from Indiana Jones I put down paper towels soaked with Goo Gone. Worked good and smelled nice (orange scent)
#22 3 years ago
chad
then they just soaked up the glue or..?
#23 3 years ago
I use paper towels too. Sprayed with iso alcohol. Let it sit for few minutes, keeping it wet.
Sprinkle flour on it, rub it around, with pressure.
You'll get the hang of it
#24 3 years ago
chad
Loosened the glue n I cely and removed fairly easy. This was on if I recall one, of the This Old Pinball episodes.
#25 3 years ago
Alchohol and flour. Iso for playfield and beer for me.
I did try goo gone but apparently did not give it the necessary time to soften the glue.
#26 3 years ago
The alcohol dissolves the glue but only temporary. The purpose of the flour is to give something for the glue to bond with in those few seconds that its lifted from.the playfield.
$ 18.95
$ 12.95
$ 36.95
$ 18.95
$ 18.95
$ 17.00
Nordic Pinball Supply
4,289
Lake Elsinore, CA
