Apollo 13 testing magnet coil with LCR meter
(Topic ID: 200189)
By GTV6
1 year ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by GTV6
#1 1 year ago
Hello everybody,
After burning fuses and transistors on the A13, we tested the magnet coil. I measured 3,1 Ohm on the coil.
Then we tested with LCR meter and compared with the same coils in a friends LAH, the three coils in the LAH gave +/- 13.500uH while my coil from the A13 gave +/- 750uH. I am not very familiar with testing inductance, can somebody here confirm the coil was burning my fuses and transistor from the moonmagnet auxilary driver board?
#2 1 year ago
Usually when some coil is below 4 Omh is bad.
#3 1 year ago
Ok, new magnet coil installed. Magnet coil is constantly fully loaded in attract mode. Immediately when I close the coindoor I hear the magnet coil working, it receives 80V without any reason.
Already changed 4 times the transistor in the moon magnet auxilary board. (there was a P40NF10L installed that was broken, schematics says P20N10L, I used STP22NE10L) I found people on the forum saying to use IRL540, I only find IRL540N for sale. Cam somebody say witch is good, witch is better??
I'm turning around burning fuses, transistors and a magnet coil. I still don't know which is the symptom and which is the problem.
Somebody has an idea?
#4 1 year ago
This is from when I got my A13.
I copied and pasted form the thread I posted it should help you.
"I just purchased the game the other day
Should have gone thru it more before playing it for a awhile. Seller stated moon was melted but I didn't realize coil was locked on still should have checked.... Lesson Learned!
Since then, I have repaired the circuit for the moon and ordered new mag coil. The circuit is a very poor design, it goes thru the segment display board than to the aux driver than to the coil.
A VERY IMPORTANT THING TO NOTE IS THAT IF THE BLUE/WHITE WIRE ON J2 DOES NOT MAKE CONTACT THE MOON WILL LOCK ON. J2 USES A IDC CONNECTOR AND VIBRATIONS CAN AND WILL LOOSEN THIS WIRE OVER TIME!!!!!!!
To repair the circuit I had to fix the following (note this also repaired the 7 segment countdown display):
Bad components on 7 Segment Display Board:
U2 - 74LS273 (if your moon works fine but countdown LED display does not replace this chip)
Q4 - 2n3906
Q5 - 2n3904
Q6 - 2n3904
Replace J2 IDC connector with molex connector.
Bad components on Moon Aux Board
Q3 - 20n10L replaced with IRL540 (NOT IRF540!!!!)
D10 - 1n4004
the components on the 7 segment display board control the moon as well you could have a bad Q4, Q5, or Q6 on that board. check with logic meter this document will help you with that.
http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/sb/sb80.pdf
#5 1 year ago
Very interesting.Will save this like usefull info.
#6 1 year ago
Quoted from arakissun:
No problem
Thanks for the moon mech I bought from you! Was able to replace my melted one
#7 1 year ago
Thanks for your answer, I already saw your post and already changed Q4, Q5 and Q6 like in your post. Countdown display does work.
I doublechecked the Blue/white wire is making contact from board to board. Q3 replaced already 5 times by STP22NE10L, because I had some. I want to buy IRL540 but only find IRL540N.
Should they work too?
#8 1 year ago
Quoted from GTV6:
you need to check the output on U2. If you replaced everything else check U2 is likely bad.
Also when you replaced Q4 - 6, did you verify pinout on some replacements it is different.
#9 1 year ago
I was thinking U3, because I have no problems with the 7 segment display. How can I check this components?
I verified Q4-6, the gave the same values on same pinout like the old ones.
Gweem's Mods
$ 50.00
2,300 (Firm)
Sale Pending!
Naperville, IL
