Hello, we have an Apollo 13 pin. The left slingshot solenoid went bad so I replaced it and the Q12 mosfet was shorted so I replace it as well. When I put the power board back in, the blanking light was blinking which I believe means the CPU board could not talk to the power board. I pulled and reseated the 20 pin ribbon cable, powered up and the shaker motor was going nuts. I then physically manipulated the ribbon cable a bit. Sometimes the shaker motor would go, sometimes teh left sling would fire and sometimes the moon would go round and round. I tried a different ribbon cable and the same result. I tested for other mosfet shorts and didn't find any, just q12 which we replaced. This seems like something on the CPU board, not the I/O board??? If I disconnect the ribbon cable all together, everything powers up okay (other than the blanking light blinking). I can't find details on the protocol between the boards. Could it be the upstream buffers??? What should I try next?
Tom
