I've had this idea kicking around in the back of my mind for a while now, so I figured I would finally ask since I could probably make use of it sometime soon. Has anyone used a vinyl cutter to make frisket masks for painting playfields?
The idea would be to have a 1 scan of the playfield, then draw the masked areas in photoshop/illustrator, send that to the vinyl cutter to get an exact mask (rather than cutting by hand and either messing up the mask or cutting into the playfield), position the mask on the playfield, then use an airbrush on the masked area.
Has anyone tried this? If so, what cutter and masking material did you use?
