(Topic ID: 259188)
Anyone successfully unlock a desktop computer? Tips?
By Guzz4851
47 days ago
  • 27 posts
  • 13 Pinsiders participating
  • Latest reply 43 days ago by LateCenturyMods
    #1 47 days ago
    I bought a used Dell mini desktop computer with a Windows operating system. Going to use it for a project.
    When I turn it on I get the dreaded “control, alt, delete.” Then it shows username as “administrator” and I don’t have a password.
    Is there a work around or some way to reset this? I’ve looked online and tried some suggestions but no luck. Maybe a computer savvy person here can give me some things to try. Thanks!
    #2 47 days ago
    Which windows? If it's 7 you can use safe mode to get around the password and let you in.
    Alternately, if you get a Dell Windows ISO for the same version on the machine, you can just wipe the machine - the license is encoded on the motherboard rom.
    #3 47 days ago
    Can't just put linux on?
    #5 47 days ago
    I did some in Xp using a Unix boot disc that allowed the admin password to be reset.
    #6 47 days ago
    If you don't need to retrieve any data, just reinstall Windows. Search for "Dell restore disk" and the version of the operating system.
    If you need to retrieve data, just remove the hard drive, connect it to another computer, and copy what you need. Then reinstall windows.
    #7 47 days ago
    Quoted from ForceFlow:
    If it's Windows 7, just bypassing with safe mode and resetting the password in safe mode is a lot faster and easier.
    #8 47 days ago
    Quoted from Guzz4851:
    Quoted from vireland:
    Maybe, but I wouldn't trust someone else's computer to be malware-free.
    #9 47 days ago
    Well, if you're hooking the hard drive to another computer and copying files off it, you've already made that trust fall. At least doing it the bypass way, it's still self-contained and can be scanned and cleaned in isolation before you pull files.
    #10 47 days ago
    To be fair, I didn't catch it was someone else's computer on the first read-through. I just saw reusing an old computer for a new project.
    I still think the best approach is just to blow it away and reinstall.
    #11 47 days ago
    On that point, we are in total agreement.
    #12 47 days ago
    Thanks guys.
    It was someone else’s I bought it for a project.
    It has windows XP.
    How does one go about reinstalling windows?
    #13 47 days ago
    It has XP? Unfortunately that's not going to run Windows 7, 8, or especially 10 at any usable capacity. Unless you're wanting to run Linux Mint, Linux Lite, or Lubuntu for web browing and some basic office applications, it's pretty useless.
    #14 47 days ago
    Thanks guys.
    It has windows XP.
    You need a Dell Win XP iso (is it Home? Professional? It needs to be the right one) to reinstall UNLESS there is a recovery partition on it. Try tapping F8 at startup and see if you get repair options. If it has a recovery partition, you can reinstall windows from that.
    You can get into the machine by booting in safe mode and just changing the admin password, too.
    #15 47 days ago
    Even if he could re-install XP he still couldn't use it after 30 days. Microsoft shut down the activation servers years ago.
    #16 47 days ago
    You can look (or ask me...) for an unlocked version of Windows XP, since this computer probably won't support a 7 and XP is not supported anymore, I don't find it entirely wrong to do it.
    #17 47 days ago
    Press F8 and I get these choices...
    #18 47 days ago
    And it’s XP professional
    #19 47 days ago
    If this is a used unkown to you PC I would just reinstall windows and start fresh. there usually is a license key sticker somewhere.
    #20 47 days ago
    Quoted from Crash:
    Maybe his project is MAME, then it's fine.
    #23 47 days ago
    Press F8 and I get these choices...[quoted image]
    It's been a long time for Win XP, but try return to OS choices and see if you get a repair menu.
    #24 46 days ago
    Download the Ultimate Boot CD, burn it, boot it up.
    Under HDD Tools, pick Data Recovery, then pick Offline NT Password Editor.
    Ophcrack for XP should work too!
    #25 46 days ago
    Quoted from LateCenturyMods:
    Seems like a lot of work when safe mode or a Dell XP disc install will solve the problem.
    Also, crack not required since Dells have the Win license encoded in the MB roms. You can reinstall from any Dell OS disk that's the same flavor.
    #26 46 days ago
    Here you go, just use a password reset key
    amazon.com link »
    #27 43 days ago
    Ophcrack only resets the password. After running whatever or getting the data off, I agree that reloading Windows from disc is the best choice, and then you have to upgrade to SP3 from disc also, since it won't activate/update with the older IE versions.
    $ 69.99
    $ 235.00
    RS Technologies
    $ 5.00
    Doc's Pinball Shop
    $ 109.99
    € 95.00
    FlipperLED
    $ 38.00
    $ 9.00
    $ 22.00
    $ 5,599.00
    Classic Game Rooms
    $ 5.00
    Allteksystems
    $ 9.99
    Bent Mods
    $ 99.99
    Filament Printing
    $ 99.99
    $ 165.00
    Pixels Arcade Games
    $ 325.00
    Gameroom Mods
    CzTV Mods
    $ 12.95
    $ 29.95
