Quoted from GPS:Hello,
Was wondring what I might check on this pin if when the roll under target is hit, it does not advance to the next letter. For example, C is lit on the playfiled, the ball rolls under the gate and at this point it should then advance to D, but it does not.
Any thoughts??
Thanks in advance.
George
There should be a complete unit that controls the letters. Without a schematic, you can remove the playfield glass and start a game. When ball ejects into the shooter lane, collect the ball.
Then raise the playfield and watch the relays beneath on the cabinet floor and playfield. Manually trigger the rollover that moves from A to B. You should see one relay unit activate. This unit probably has a stepper with a bakelite pad with contacts.
Once you have identified the stepper, manually activate the switch and watch the stepper. Keep manually activating to see the stepper for each letter. My guess is that you need to clean the bakelite contacts with sandpaper and alcohol. You should be able to turn them from dirty to bright brassy color.
For more details on cleaning your contacts, visit www.pinrepair.com and review the EM section.
That is what I would do SECOND.
The FIRST thing you need to do is order a schematic from PB Resource ASAP!!
Good Luck!
Marcus
