(Topic ID: 270421)
Anyone know what this is for on my Subway score reel
By tscottn
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by tscottn
#1 3 years ago
The pic shows a junction between the two bottom connections of my ones reel on a gottlieb subway. None of the other reels have this and it seems to get very very hot. couldn't find it on the schematic, and I was wondering what it would be for or if it was added by a previous owner for something. Right now my reels are doing some weird things and I am just wondering if this might be part of the issue? Thanks.
BTW I know the return spring looks over tight., The other end is very stretched. I have a new spring on order.. will replace when i get it.
#2 3 years ago
It's a resistor. Confirm on your schematic though. It will looks something like this:
#3 3 years ago
Quoted from currieddog:
Thanks currieddog This is the only resistor I can find on the schematics., Its for the A alternating relay to the Ones unit it looks like., im still not sure what it does exactly..
#4 3 years ago
It supplies some voltage to the A coil at all times, so that the contacts on the disc (on the ones reel) don't have to take the coil all the way from 0 to 25 volts. I think this is so the contact points on the disc and/or the wipers are not subject to as much arcing. When the ones-unit wiper is not completing the circuit, the A coil is not pulled in.
Your excerpt of the schematic shows that one of the things the A relay does is switch the score values of the kicking rubbers back and forth. You should find another switch for relay A over on the lighting portion of the schematic where the "10 points when lit" playfield lights switch back and forth. Every 1-point score changes which of the kicking rubbers is worth 10, with the other being worth 1. There may be other alternating values elsewhere.
.................David Marston
#5 3 years ago
Quoted from dmarston:
David, thanks for that great info. After looking moire at the schematic and reading through your post I am now a little more familiar with what is going on here. Thanks again!
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/anyone-know-what-this-is-for-on-my-subway-score-reel and we tried optimising it for printing. Some page elements may have been deliberately hidden.
