(Topic ID: 33602)
anyone know how to adjust last action hero crane?
By stuartr7
10 years ago
#1 10 years ago
HI Guys,
Does anyone have a last action hero pinball?,
I recently got one and the crane is parked in the middle of the play field, when the crane is active it rotates to pick up the locked ball from the right side, but on the way back as it traverses it stops short of the left ramp by a few inches and stays parked in the middle?
anyone found a solution for this?
#2 10 years ago
Theres an allen key screw underneath the crane arm (top of playfield). Once you loosen, you can rotate or remove the top of the crane.
You can see it through a circular hole and need to poke your allen key in
#3 10 years ago
Hi,
does anyone have a detailed with pics on this, I moved the crane, before it would park middle and when it moved to the right point and try to push past the yellow collection point.
now it moves from left to right short of both points and so the crane never hits either switch!!!
Thanks for any help
#4 10 years ago
There are no pictures that will help you -- a picture with the crane parked in normal position and picture parked for ball pick up.
The crane motor always turns in the same direction. There is a cam on the motor that operates the crane in a 145 degree arc (per the manual.)
To adjust the crane, go into crane test. Manually operate the crane motor by pressing the start button. Apply just enough set screw pressure so the crane moves but will slip on the shaft when it hits a limit switch. You should be able to get it adjusted using this technique. The display will indicate limit switch actuation.
#5 10 years ago
hi, must be going through a dim period, where is the set screw ?,
I found judge dredd easier to work on than this!
would love to see an exploded diagram of this but can find nothing in the manual?
#6 10 years ago
In the access hole on the side of the crane is a socket head set screw that requires an allen wrench to un-tighten and tighten. I don't recall the size, I think it's either a 5/32 or 9/64 wrench.
#7 10 years ago
thanks you are a genius!!!!,
I will have a go at this once the relatives are away, counting the hours !!!
thanks
#8 10 years ago
Very cool! My LAH crane could use a little adjustment as well. Thanks for this!
8 years later
#9 1 year ago
I came across this post tonight trying to fix this exact issue, and 8 years later it helped. I love Pinside and this community. Thank you.
1 year later
#10 8 months ago
Quoted from minnesota13:
For future reference. It is 9/64”
$ 39.99
Mitchell Lighting
Led
Protection
$ 78.50
$ 18.95
Arcade Upkeep
Other
$ 105.00
Arcade Upkeep
Other
Professor Pinball
Interactive
Men
$ 1.29
Daddio's 3D Printed Mods
Toys/Add-ons
$ 5.95
The Pinball Scientist
Protection
$ 5.00
Protection
Slap Save Creations
This page was printed from https://pinside.com/pinball/forum/topic/anyone-know-how-to-adjust-last-action-hero-crane and we tried optimising it for printing. Some page elements may have been deliberately hidden.
