I have a window in my house leaking and I'm not sure how to address the issue. It's at the top of the window and right were there is caulk between the drywall and the window.
I'm assuming that if I were to just replace the caulk that has failed on the inside, that isn't going to do anything other than let the water run down inside the wall. The problem is that everything says that you shouldn't need caulk on the outside of the house if you have vinyl siding.
Does anyone know how to fix this leak correctly? Thanks!
