Quoted from daveispinball:The issue keeps evolving... now you can see in this vid... Game turned on (finally), could press start... no ball popped out so I used the captive to see what would happen. When I high different targets the loud knocker will go off randomly. When I sent the ball into the sewer it disappeared forever! It wouldn't pop out (I'll have to grab it myself)....
Any thoughts from the vid would be appreciated.
A/C select relay not working.... Data East/Sega put the low use coils/flashers on the A side instead of the C side, so when the A/C relay fails the game is unplayable because the kickout coils can't fire.
You need to go into diag and try the solenoid test. If when going through the test a flasher fires instead on a coil or a wrong coil fires, this is the culprit.
I believe that Stern (data east / sega) put the A/C (left/right I believe is what the manual calls it) on solenoid 10. Check your driver circuit for solenoid 10 if the wrong coils fire for 1-9.
