In audio equipment, this is almost always the case. In a well designed circuit, externally injected noise shouldn't be much problem- not that it can't be in practice.
and/ or high frequency noise.
Quoted from viperrwk:25-year old electrolytic that tests with appropriate ESR, should I replace it anyway?
I think this depends on several things: size/ cost, difficulty in changing later, time you expect to own item/ purpose for being in there in the first place, and possibly most important, the possible consequences to other parts of the circuit should it fail. IOW, if the transistor that's going to die as a result is NLA, and not easily substituted (think germanium) then definitely.
For the most part, they're virtually free for smaller values. If it's already out to test, why not just replace? It's 25 years old, and old electrolytic WILL fail. A $50 power supply cap is another story.
