Looking for the manual/schematics. I have the operators handbook already. PM me if you care to share
Yep, I need online schematics too. I need an online link so I can ask for tech help on a recurring switch matrix issue.
-mof
http://www.firepowerpinball.com has a better than Williams schematics/board layouts.
The above + the Op handbook from
http://mirror2.ipdb.org/files/177/Williams_1981_Barracora_Operators_Handbook.pdf
should be enough to fix 99%.
Quoted from vid1900:http://www.firepowerpinball.com has a better than Williams schematics/board layouts.
Ok, so if I understand this correctly, the Firepower Schematics should work fine for other System 7s, and then use my handbook to reference the switch diagram for this particular machine. Is that correct?
-mof
Quoted from mof:Ok, so if I understand this correctly, the Firepower Schematics should work fine for other System 7s, and then use my handbook to reference the switch diagram for this particular machine. Is that correct?
-mof
Correct.
This page was printed from https://pinside.com/pinball/forum/topic/anyone-have-a-barracora-manual-in-pdf-format and we tried optimising it for printing. Some page elements may have been deliberately hidden.
