New! Dark mode!
(Topic ID: 243180)
LETS Drill BK3000 to properly add magnasave button? NEED a template from BK BK2K
By Whysnow
1 year ago
  • 231 posts
  • 94 Pinsiders participating
  • Latest reply 73 days ago by swillie
  • Topic is favorited by 10 Pinsiders
There have been 31 images uploaded to this topic. (View topic image gallery).
2019-06-24 19_20_09-back to the future meme chicken - Saferbrowser Image Search Results - Internet E (resized).png
There are 231 posts in this topic. You are on page 1 of 5.
11
#1 1 year ago
Sorry if this have been covered elsewhere (pls link if so).
The lock down bar button is pretty much pointless for the mangasave.
Has anyone drilled their cab yet to add a 3rd button?
Can you just tap into the existing switch to double up for player option?
Does it work better in this position for reaction time?
Is the magnet itself to far over to properly save and it is not merely the lock down button placement that sucks?
#2 1 year ago
I’ve heard a few guys talk about doing that. I’d personally like the button in the old school spot. Great idea
16
#3 1 year ago
"Pretty much pointless". You guys are so dramatic.
#4 1 year ago
Quoted from Chalkey:
not really being dramatic, just factual.
I am really digging BK3000, but the one real flaw is the magnasave on the lockdown. Look at Bk and BK2000, what % of the time are you able to save an outlane drain on the right with a lit magnasave? For me, it is probably 50%
BK3000... maybe 5% and that is due to it only being worthwhile with a super slow roller and you execute for the safety net and not the real magnasave.
To me this is due to my slower reaction time and need to plan ahead for the slap all the way over the top to the lock down bar.
Back on topic, have anyone drilled the cab yet? Thoughts on placement? Any issues with placement and cab internals?
Did it help return the intended "feel" of the magnasave to what it should be?
#5 1 year ago
If I owned this game I think I would drill the third hole, go for it!
#6 1 year ago
Quoted from Whysnow:
I’ve played 3 different Pros now and I agree I’m magnasaving maybe 5% of the time.
I think if one is going to do this mod, the ideal placement is the same distance and angle as Munsters Prem/LE. That way it will look “factory” in a lineup that contains Munsters and any other future titles that have multiple buttons on the RHS.
#7 1 year ago
Talked about it at PATZ. It would more convienant to move the button. Following the first 2 games pattern.
#8 1 year ago
Quoted from Yoko2una:
Why would you not use the same positioning as previous games?
#9 1 year ago
I would temp wire a foot pedal first, before drilling.
#10 1 year ago
Quoted from OLDPINGUY:
That was a discussion point.
Know any good pedals that would work easily for this?
I figure it would be easy to wire out the speaker hole.
I am guessing a foot pedal while cool, won’t have the response time needed or equal to the OG placement.
#11 1 year ago
The magnasave is a joke on the game .
The button on the side would feel better to hit but I don't think it matters. The magnet is either too far away from the outlane or not strong enough to grab the ball.
Only works when it's like a slow ball and 50+% chance it'll inlane anyways. Never had it worked when I 100% needed it, only when I did it where it probably was gonna be safe anyways or when the ball is bouncing back up the playfield rather than into the outlane.
Is there a magnet strength setting?
#12 1 year ago
Quoted from InfiniteLives:
Yeah, even with my hand over the button ready, there are a ton of times the magnet just can't manage to grab the ball when it clearly should be able to. I've seen my original black knight pull a screaming ball like two inches away back into play
Does anyone know the specs on the magnet? Is it recessed as deep?
#13 1 year ago
That sucks, I remember when I owned an original BK it would grab a ball that was an inch down the outlane and hauling ass, and pull it right back up...
How can they mess up on a tried and true system
#14 1 year ago
I’m sure with all the 3D printing options available someone could come up with a design to mold the right flipper button and a secondary magna-save button together so no drilling would be necessary, maybe a design similar to a Pin2000 style flipper button.
#15 1 year ago
Sorry, I dont specifically, but I have some somewhere at work that attached to a flex shaft, or a music pedal.....but I
like the Pinball 2000 option...does it have the same hole size to slip in?
#16 1 year ago
Any original black knight I've played if the ball was committed to the outlane it was gone. The magna-save would ensure a 50-50 ball ends up in the inlane and nothing more.
If you guys want to test it out just run some alligator clips from the button leaf switch tabs out the coin door, painter tape another leaf switch to the side rail. The game plays with the coin door open right? Or you could temp remove the coin reject buttons until you decide you love it and go the hole saw route.
First one with the grapes to make sawdust wins me posting a "Picard with head in hand" meme.
#17 1 year ago
Play a better copy? I've seen many with weak magnets if they haven't been fixed up properly
33
#18 1 year ago
my original bk magnet would suck the balls off superman.
#19 1 year ago
Quoted from ccbiggsoo7:
Lmao!
-Mike
#20 1 year ago
I use it successfully all the time. Even on the *GASP* dreaded lockdown bar! It is a little overstated when you called it pretty much pointless. But hey, you want to drill an extra hole into your game, knock yourself out. Just remember, if you go through all the effort to drill a hole and run another button to that switch, and you still don't have the reaction time to save your ball......you just lost your most valuable excuse. "DAMN BUTTON IS IN THE WRONG SPOT!"
#21 1 year ago
I’d put a 1/4” jack on the bottom of the cabinet and then a ts cable (standard guitar or keyboard cable) to a momentary sustain pedal. Momentary will connect the circuit as long as it’s pressed (does not latch).
—Kevin
#22 1 year ago
Needs to go on a T-shirt!
#23 1 year ago
Lame! Deal with it
#24 1 year ago
No but seems like a good idea. Can you do it and report back? I'd like to know as well so I can do it yo mine.
#25 1 year ago
The extra buttons on Munsters are WAY too close for this purpose. I would be hitting it all the time by mistake and wasting my magnasaves.
Steve would say that you need to play better.
#26 1 year ago
Quoted from John_I:
+1
i dont like where there are...
same position as BK & BK2K seems perfect
#27 1 year ago
Possibly a hole in cabinet wouldnt be needed. Im wondering if an original button could be hollowed out and have a small hole in center where finger would activate magna save via 2nd switch?
#28 1 year ago
Guitar Foot pedal. I’d do that the second i got the machine.
#29 1 year ago
Owning both BK and BK2K. If I bought a BKSOR it would be the first thing I did. Already was chatting about this to a couple people myself. I'm pretty sure you can jump from the original wires and us that. Or just unhook them and run to the new button.
#30 1 year ago
Next we will hear they outlawed the good magnets around the time of the demise of Diamond plate. #90sWilliamsQualityorBust
#31 1 year ago
Show me sawdust
27
#32 1 year ago
You aren't drilling a hole in a Stradivarius, what's the big deal? It's just a pinball machine. If you want an extra button, make one. Make the game as enjoyable as possible. I drilled a second button in a couple high end games I sold to a friend with one arm. It was tough to drill into the artwork, but in the end it made the game enjoyable for someone that couldn't otherwise play it. These are games and meant to be fun. Have fun with them!
#34 1 year ago
Quoted from zacaj:
Rhetorical answer to a rhetorical question: name me the last Stern game that had a second button on the side rather than the apron.
#35 1 year ago
Quoted from vireland:
With that game's soundtrack, that's worth a facepalm and a 'dohhhhh, wish I'd thought of that.'
#36 1 year ago
Quoted from EalaDubhSidhe:
munsters
#37 1 year ago
See? I'd already forgotten!
#38 1 year ago
you're getting old Eala...
but dont worry, same story for all of us
#39 1 year ago
The magna save is one of the main features for BKSOF. Why have a game that you cannot use one of the main features on? If I ever own a BK I would totally drill out an extra flipper button on right side with correct distance. I would not disconnect the lock bar magna save button but I would tap into it and have both the side flipper button and the top button that can operate. I actually think it is a great idea and if it catches on Pinball life could sell kits, etc? I think instead of decreasing a games valuation-it could actually add a premium. I would want a BK that operates properly
Make it so
-3
#40 1 year ago
Go ahead and drill but I guarantee you; if you try to sell it most people will view this as a negative and ding the value because of it.
#41 1 year ago
Is it possible (and would it even be a viable option) to move the button to the far right or left of the lockdown bar, to hit with your thumb while your hand is still in normal playing position?
You’d need to drill in the lockdown bar but that is easy and easily replaceable.
11
#42 1 year ago
Quoted from kermit24:
No way it would bring value down imo, your fixing a factory design flaw if anything.
Why anyone really though that was a good idea still has me scratching my head.
Honestly if I had that game and could not save balls consistently it would be the first thing I did.
#43 1 year ago
Someone needs to design a wireless stick on button for no drilling solution.
#44 1 year ago
F resale value... it's a game. Meant to be played. If the lockdown button is so crappy... and a traditional cabinet position will boost play value, move the button.
#45 1 year ago
If Steve Ritchie was fine putting the Magnasave button on the lockdown bar, I’ll just deal with it as yet another challenge he is throwing at us as the designer. I’m sure Steve had enough sway to have the extra button located on the side of the cabinet if he really wanted it there, especially given that Munsters has two additional such buttons.
And while it may take some getting used to for us BK veterans (making the game that much harder for us, which again I personally welcome), I also see this as a great marketing attraction for the average person first approaching the game, scoping it out, and deciding whether or not to drop some coin into it: “Wow! This game has a magnet I can use to save a ball from going out the side!” The button is right there, front and center, blinking at them with a big arrow pointing to it. And this special button can do something to benefit the player besides launching a ball, firing a cannon or just scoring points: it can keep balls in play longer. That’s a nice little something extra to entice potential players with.
Of course, actually mastering its use during live game play will be even more difficult for these casual players than it will for us with a lot more playing experience, but oh well: I guess they will just have to put some more money in the game and keep trying. And that might very well hook a few new players on pinball for life. Sounds win-win to me.
#46 1 year ago
I asked Steve Ritchie about this at MGC. He very enthusiastically showed me and other onlookers that you simply need to hover one of your hands over the magna-save button while playing the flippers with the other.
You’re all just doing it wrong.
#47 1 year ago
I've gotten pretty good using the button where it is. I saved two balls on my second game. No way am I drilling my LE. I will install wireless if possible, but beyond that I will do the Steve Ritchie method.
#48 1 year ago
Quoted from pinmister:
The magna save is one of the main features for BKSOF. Why have a game that you cannot use one of the main features on?[quoted image]
Because this is a non-problem that internet stooges are blowing way out of proportion.
A lot of talk but still no sawdust, drama queens!
#49 1 year ago
whysnow just drill it in and post the results.
#50 1 year ago
Quoted from cletus:
Yes technique is key, you have to be quick on the stick to make use of the Magna
$ 65.00
Lighting - Backbox
Arcade Upkeep
Filament Printing
$ 499.95
Pin Stadium Pinball Mods
$ 8,999.00
Classic Game Rooms
