(Topic ID: 110000)
Any Way to Customize Audio on a System 11?
By herbertbsharp
5 years ago
  • 12 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by herbertbsharp
    #1 5 years ago
    Does anyone know of a way to customize the audio on a System 11? Ideally I would just want to edit the roms and burn them to a chip. Hoping for something like pinball browser but I have a feeling there isn't something like that available.
    #2 5 years ago
    Even if there were a way, I doubt you'd get any extra speech on there than it originally had because of lack of memory banks. Having to extract the code, inserting the exact format, then recompiling. You may as well PROC it for $350 which will allow you to run original and new code. Just look at what denasi did with earthshaker:
    #3 5 years ago
    Quoted from toyotaboy:
    Thanks for the info. The video is pretty cool too. I really just want to replace some call outs... I want to put the machine on location so I'm not sure I'd want PROC but I'll into it. Thank you
    #4 5 years ago
    Quoted from herbertbsharp:
    Why? pretty sure PROC can do non-freeplay. After all, the big lebowski runs it and it has coin slots (capable of being put on location)
    #5 5 years ago
    I guess because I thought you had to have it hooked up to a PC to work. I know I could put a small one inside the cabinet but I was hoping to avoid that I guess. I t would give me a lot more freedom though, so it might be worth it.
    #6 5 years ago
    http://www.pinballnews.com/learn/p3roc/index.html
    "The computer therefore has very little to do and can thus be very small. In fact, most games can run fine using a small single board computer like a Raspberry Pi or Beaglebone, and they can run stock operating system images without low level kernel hacks"
    raspberry pi A plus is now $20 and runs on only 5v @ 1 watt of power.
    #7 5 years ago
    Pinsound makes a board that fits some system 11 games. You can use what ever sounds you want. There are some other posts about on pinside.
    #8 5 years ago
    Quoted from mbt:
    WOW! Pinsound is exactly what I would want, but unfortunately the game I want to use it on has a system 11 sound board but it isn't compatible. I want to use it on a Bally Atlantis. Really bad.
    That is really good to know, I appreciate that a lot. I wish it would work with Atlantis. I also really want to leave the rules in tact and just change the sounds. Looks like I would have to re-write all the rules?
    #9 5 years ago
    Quoted from mbt:
    So you guys helped me out a lot. Your comments helped point me in the direction I think I'm going to go. I think I'm going to tap into the switch matrix and hook it up to a beaglebone or raspberry pi. I'll write the code to play the sounds I want. I'm not sure if I can do multichannel audio with them yet, but if not I'll just hook 2 up (one for BG music & one for SFX) through a mixer. This is going to be a really fun (and probably frustrating at times) winter project. I'm pretty happy because this option will give me the creative freedom I want with audio and I'll be able to keep the rules in tact. Thanks!
    EDIT: LOL looks like tapping into the switch matrix isnt as simple as I thought... UGGGG need to figure out how to do this....
    #10 5 years ago
    If all you really want is to re-do sounds, I think you're much better off just buying an mp3 trigger:
    https://pinside.com/pinball/forum/topic/custom-sounds
    Keep in mind you'll have to turn off the existing sounds, and you'll have to create a separate switch from the existing pinball's switches to trigger them (switches have a constant 6vac running through them).
    it's cheap, and it's simple (if you just use the switches, not running serial commands). If you want REAL control, just buy a raspberry pi and wire it up:
    https://learn.adafruit.com/playing-sounds-and-using-buttons-with-raspberry-pi/overview
    #11 5 years ago
    Raspberry pi it is! Got one ordered. Programming the sound stuff will be easy, if any one has insight on how to read data going to the sound board I would appreciate it. I'll probably just run a double set of switches though
    #12 5 years ago
    OK, I have a raspberry pi up and running using pygame within python to play audio based on switch inputs. It gives me a lot more control and flexibility than the mp3 trigger was going to. I think it will really help give it a more polished feel. Minus some fine tuning (and expanding the GPIO to 30~ inputs) the audio framework is pretty well set up. I *just* need to figure out how to scan the switch matrix. I'm guessing I need to be able to determine when the the CPU pulses the columns and simultaneously check the rows - seems simple lol . There has got to be a way to do it but I'm certainly no EE. Any pointers are very welcome!
    Great American Pinball
    $ 19.95
    Little Shop Of Games
    € 3.95
    Multigame
    $ 79.95
    $ 999.00
    $ 35.95
    MicksPinball
    $ 72.95
    $ 48.00
    $ 69.99
    $ 999.00
    $ 18.99
    $ 54.00
    $ 208.87
    Various Other Swag
    Shoot Again Pinball
    € 80.00
    YOYOKOPTER MODS
    € 40.00
    YOYOKOPTER MODS
