Hi guys, not to beat this to death - but the Opto on my RCT has a receiver board that sits right next to a metal lug (I don't know the part exactly) when the playfield is lowered. This causes the board to short out, and then you're out another $$ every time.
I am awaiting a replacement, and will make sure there is some type of good solid insulation between them, but in the meantime I would like to bypass this OPTO to make sure the other switches in series are all working.
I see that the transmitter has a 2 wire connection (+/-) and the receiver, logically, has the same power connection, plus 2 additional connections. Is this a simple NO/NC type deal, or is the receiver board sending some digital or analog information back to the CPU to show state? I want to be able to 'plug' this hole so that the other micro swiches in the series will work and I can more fully test the machine. I might also decide to bypass the OPTO all-together if it continues to be problematic.
Thank you for your time and assistance!
Adam
