(Topic ID: 3931)
Any tips to make the Fish Tales topper a bit quieter?
By BonisEnr
10 years ago
  • 38 posts
  • 28 Pinsiders participating
  • Latest reply 1 year ago by chubtoad13
  • Topic is favorited by 14 Pinsiders
#1 10 years ago
I must say, I love the fish topper on this game and how it goes absolutely mental when you hit some shots, but my neighbours, not so much I have temporarily unplugged it, but has anyone found a good material to put on the mechanism behind the fish, to reduce the noise when it flaps? Maybe a sponge, foam pad, polystyrene... Has anyone succeeded at this with some home-made solution?
#2 10 years ago
I think either you leave it plugged in or you don't. Mine had the wire cut when I got. I soldered it back on. That's why I don't live in an apartment/condo/townhome!
#3 10 years ago
I cut wires to solenoid on mine. Not only is it noisy, but it will tear the fish.
#4 10 years ago
I unplugged mine as well, it is cool to hear it clacking like crazy when your doing good, but IMO it's just to loud and annoying for home use...
#5 10 years ago
Quoted from twizz63:
Quoted from tomdotcom:
Blasphemy!!!
#6 10 years ago
Blasphemy indeed! I love hearing Fish Tales' topper and the monster fish roar from the rest of the house when friends are over! But then again I have no neighbors on that side of the house
#7 10 years ago
I love it too, but the wife and 4 month old baby DO NOT....I need a bigger house with seperate game room, then I will plug it back in
#8 10 years ago
Got mine plugged in.......would only turn it off if neighbours could hear. I like it!
7 months later
#9 9 years ago
last week i did a noise reduction MOD on my congo. LOL
it worked. will put a thread on it soon
#10 9 years ago
Try this
#11 9 years ago
Quoted from BonisEnr:
I bought some ball dead foam from pinbits and cut out a donuts shaped piece to attach to the bracket that the back of the plunger hit.The plunger passes through the mentioned bracket.It makes a much quieter non metal clanking sound.
#12 9 years ago
Try turning up the volume on the machine, it will make the flapping less noticeable.
#13 9 years ago
Quoted from bballfan:
I did the above, and also attached a big plastic washer like you would put under a slingshot for ball strike protection to the fish where the plunger strikes it. I covered the plastic washer with fabric and filled it with a small amount of ployfill. Very quiet... you just basically feel the vibration through the machine and don't hear much of the fish. A non-pinhead friend thought the machine had a shaker in it and never noticed the fish until I pointed it out. The fish moves just as much as it used to, with very little noise, so I was happy.
#14 9 years ago
Shane, do you happen to have a picture of that? I guess I could get off my lazy ass and take a look at the assembly myself.
#15 9 years ago
Quoted from Dewey68:
yeah please
i unplugged mine it echoed too damn bad in basement when wife trying to watch tv LOL
#16 9 years ago
Here is a well illustrated instruction on where to place the dead ball foam.
Remove the bracket holding the coil also remove the plunger.Cut out a piece that will fit and allow the plunger to pass freely.
#17 9 years ago
I played on a FT in Houston at the HAAG show that I thought had a shaker motor installed because when the topper went off, instead of the clacking, it shook and actually felt a bit like a fish on the line and was really cool. When I talked to the owner, he said he didn't do anything special to the game, so I'm wondering if there is a certain configuration that the original game designers had that wasn't really "clack-based" but instead relied more on vibration? Anyone know?
#18 9 years ago
Quoted from PinballHelp:
wow that would be sweet!
#19 9 years ago
Here is a pic of the padding on the fish...
#20 9 years ago
While I had the topper cover off to take that pic, I added some leds to the fish to make it look closer to the monster fish. Check it out!!!
#21 9 years ago
I Un-Pluged mine @ 1 Tyme , Got annoying.. Till i read where you can adjust the Coil , i also put a Blue habitrail Rubber ball stop where the Rod smack's the Tail.. It worked !!!
1 year later
-1
#22 8 years ago
Quoted from BLACK_ROSE:
How can you adjust the coil?
Is there an option in the settings somewhere to turn off the topper there without the need to disconnect the wires?
#23 8 years ago
Dead stop foam @ the back of the plunger worked for me
2 months later
#24 8 years ago
put a shooter (plunger) tip on the coil armeture
#25 8 years ago
Gone Fishing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#26 8 years ago
mine is quiet somebody disconnected it .where does it connect to?thanks joe
#27 8 years ago
Remove the armature and roll a star post rubber or 2 down to the base and reinstall.
#28 8 years ago
Quoted from tracelifter:
I just did this and I can vouch for it. Used one star post rubber and put on a shooter tip and it's super quiet but still shakes. Took 4 minutes at most. MUCH BETTER! Actually more realistic, as stated above it is now like having a fish on the line...
#29 8 years ago
Take the whole assembly off, and sell it to me , that will make it quieter !
9 months later
#30 7 years ago
I'm having trouble with this mod. I tried up to 4 star post rubbers and the topper is just as loud as it ever was. Am I putting the rubbers in the wrong spot?photo 1.JPG
#31 7 years ago
You have them in the right spot, three should be quieting it down quite a bit.
#32 7 years ago
All I did on mine was add a single 5/16" post rubber down on the armature base where you have yours located--but I also added a piece of Pinbits Drop Dead Foam behind the Fish's Tail.
That did the trick nicely: I now get a nice "thump" kind of resembling a shaker effect (no more metal clanking).
Good luck.
#33 7 years ago
I got it working now. I switched the rubbers to white (maybe a little more give?) and only used 2. The fish sounds like a nice thud now. Thanks for the help tracelifter!
#34 7 years ago
Update: I ordered a plunger tip and use one star post rubber. It is PERFECT now! Its loud enough and gives a nice pull feeling that was missing before the plunger tip. Thanks guys!
Quoted from freddy:
1 month later
#35 7 years ago
Is there any way that i can buy a kit or the correct parts to build a replica of this for my machine? I'm missing the topper
1 year later
#36 6 years ago
Yeah I'm looking for a whole assembly too. Anyone who hates the sound of it clacking can do what Freezie suggested and take the whole thing off and sell it to me . Easy fix for the noise is a shooter tip rubber on the plunger tip as suggested by Freddie..
4 years later
#37 1 year ago
How do you get inside the dome of the topper? I can’t figure out what it takes to takes those screws out
#38 1 year ago
Quoted from Diver12:
If I remember correctly they require a security torx bit. T-20 or T-25, I believe.
Does the screw head look like a Star with a post in the middle of it?
