New! Dark mode!
(Topic ID: 61134)
Official Seawitch Fan Club ... All Welcome
By DirtySouth
7 years ago
  • 995 posts
  • 120 Pinsiders participating
  • Latest reply 29 days ago by fabsj82
  • Topic is favorited by 43 Pinsiders
There have been 361 images uploaded to this topic. (View topic image gallery).
There are 995 posts in this topic. You are on page 20 of 20.
#951 84 days ago
Quoted from Krupps4:
Anybody know of where I can get a coin door for a Seawitch? The one I have is kind of beat up (see pic) and I am looking for something a bit cleaner. Thanks in advance!
Disassemble the door and soak the door and trim in evaporust. Paint the door, trim and bolts in silvertone hammer spray paint. Pinball Resource may have a coin reject button, or you can try Marcos. Buy new coin door large square decal and a credit button decal. You door will look brand new.
#952 84 days ago
Quoted from bluespin:
Wow. Thank you! That’s great advice. Will do it.
#953 84 days ago
With the right tools and some sheet metal skills, that coin door can be fixed so don't throw it away.
#954 84 days ago
That coin door looks better than most I see for sale used. Does it close smoothly? The bottom right edge looks like someone tried to pry it open at some point.
#955 84 days ago
I’m actually picking it up Thursday evening, so I’m just working ahead. With that being said, I believe it closes okay. It’s got a relatively clean playfield. Cabinet is solid. Repro backglass. Price is right. I’m really excited it get it.
#956 84 days ago
How bad is the inside of that door? I need all the framework to hold the coin mechs since an op made it unable to be competition. If you get one I might buy some of the scraps tgat are missing from mine if you are interested.
#957 84 days ago
I’ll have coin door guts (and a face that’s got a padlock hasp on it) available as soon as I finish putting mine back together for anyone who’s interested.
#958 84 days ago
Quoted from pinheadpierre:
Nit gonna jump in front of him if he needs it but here is what I have. Worst part is the front piece that holds the coin acceptors was riveted to hold a blank piece of sheet metal blocking coin entrances. I think I might need the harness to, or rewire the other 2 coin switches.
#959 84 days ago
You can dremel out those pop rivets from the other side. The chutes and everything else might be a bit harder to source, but you might be able to trade the whole door with someone who has no intention of ever routing their classic stern and would take a few bucks instead.
#960 84 days ago
Quoted from Tomass:
I’m picking the Seawitch up tomorrow evening and will send pics of the inside of the door. I’ll circle back to everyone then - Pinheadpierre and Tomass.
Thanks everyone. Much appreciated.
#963 80 days ago
Corrected the volume pot hack (i mean it worked but wasn’t pretty) on Seawitch today. JT Amusements sent me an OEM pot which worked perfect
D3B6630F-74E2-449A-B0CE-97288A5380A8 (resized).jpegF7C9E6E0-1EF9-4612-B8FD-2612CE069A0B (resized).jpegA0AA9029-EF04-4C4A-B618-CCC9A176650B (resized).jpeg
#964 80 days ago
I want your apron. it looks 10x nicer than mine
#965 79 days ago
Finally got around cleaning up a drop target bank. I had a few new drops in stock, gotta wait for the rest to come in this week.
EBC90CE7-B7B4-47FF-9DF4-7D65489CBC0D (resized).jpegC399E0B5-614B-4016-97C7-931A801E2776 (resized).jpeg045335C0-3A90-4A0A-875A-E98D0A366B69 (resized).jpeg75BD660F-9E4A-4392-AAE5-E56716E9BE89 (resized).jpeg
#966 79 days ago
I also did this today. Robbed an atx power supply from an old pc and fashioned my very own bench top board tester. This thing had a shit ton of wires so i opened it up and cut out what i didn’t need, and at the same time grounded the green wire that used to run to the power button so i can just use the on/off switch for it now. I did this inside the housing so you can’t even see it.
I kept enough wires to create two harnesses with 4 pin molex plugs on them. I doubled up each source (5V, 12V and ground) because why not. I still cut out a bazillion wires lol. One harness has -12V also.
What i plan to do next is create “adaptors” for each type of board i work on. I just need to figure out which voltage goes to which pins on the mpu (or whatever) and build the new connectors accordingly. I know i can use alligator clips to the test points but i like this way better.
1F8EAB67-A51C-4117-906B-6A8C23A49FF8 (resized).jpeg247DF532-7D22-46CD-AD37-D231B9786403 (resized).jpeg
#967 79 days ago
Quoted from Tomass:
I’m just circling back on our discussion regarding the coin door. I picked up the pin yesterday and the coin door is better than expected. I’ll clean it up a bit and one of the coin mechs needs to be refastened, but I’m very happy with it. Thanks everyone for the advice and offers.
B7053D4B-4630-4A4A-A892-D4974237483D (resized).jpeg708A2BA6-F2AD-41C7-AA99-569F14EAA3EC (resized).jpeg
#968 74 days ago
What are the original flipper band colors for a Seawitch? I’m looking at the flyer online and it seems like yellow for the upper and blue on the lower. The Marco rubber set comes with all red. If anyone knows for sure, I’d really appreciate some definitive clarification. Thank you!
#969 74 days ago
Great question - following. I always thought all 4 were yellow based on a thread of people looking for yellow rubbers for it (pinfest thread i think). This is what my Seawitch came with also. So i replaced with all yellow. but what do i know lol.
#970 74 days ago
Quoted from Completist:
I’ve tried to do the research, but definitely no clear answer. I’ll see if I hear from anyone else, but I’m guessing it is all blue, all yellow or maybe a combination of the two. While I have your attention, are these the right acorn nuts for a Seawitch? I put in a order for some that ended up being too big. I guess I’m not that seasoned enough to just look at the post and know the size. Thanks in advance.
#971 74 days ago
Mine had those white rubber things that just slip over the posts. My F2K uses the metal acorn nuts tho.
#972 74 days ago
I don't believe back in the day that you could get flipper rubbers that were anything other than Red or Yellow... never saw Blue out in the wild.
I mostly use red for everything anyway, ultimately it doesn't make that much difference.
#973 74 days ago
I’m guessing yellow, but it really doesn’t matter. Every color under the sun is available now. Pick a color you like rather than submitting to the palette limitations of the time of original production.
#974 73 days ago
So I finally got all the drop target banks cleaned up with new targets. 7 of them were proper, the 4 in the middle were not. But didnt think i’d like 4 really white ones and 7 clean but not so white ones. So they all are new now.
#975 73 days ago
Heres what they all looked like coming out. The before pics didn’t quite depict just how dirty they were.
I didn’t go too nuts. As in i wasn’t trying to remove every single scratch. Just get back to the factory shine with a bit of elbow grease and some Mothers.
0921B0FA-14A5-43D4-A837-B031CA9FB19C (resized).jpegC28F866D-EE3D-4121-8671-0B919B78AC7A (resized).jpeg
#976 73 days ago
I should of listened to Cotton. They look good and function great, but make all the other mechs look worse than before. Guess i’m doing those next...
#977 73 days ago
May I suggest that you protect your new targets with a strip of mylar? You need not cover the entire face. A 3/8"or 1/2" strip of mylar covering the ball travel area will shlep to keep them looking newer and cleaner for longer.
#978 73 days ago
You have them all shined up. Now take the next step and spray a light coat of clear Rustoleum to keep them somewhat shiny. They will start dulling out and pick up a white cloudy hue if not hit with a little bit of clear. But then again, it does not really matter unless you are going to be entering play fields propped up beauty contests.
If you have not done so, you should wax the land that the targets set on. If you wax the land and the landing points on the targets, they will drop like rocks.
#979 73 days ago
What Mothers product did you use? The cleaning wax?
#980 73 days ago
I’d recommend using Blitz wax. https://www.pinballlife.com/search.html?Search=Blitz
#981 72 days ago
I have Blitz wax that I use for playfields, but does that also work to clean the metal parts of the drop target mech? I apologize if these are basic questions but I was thinking I should clean the drop targets like Completist did.
#982 72 days ago
For cleaning metal parts up:
Simple Green
https://www.google.com/search?client=safari&rls=en&q=simple+green&ie=UTF-8&oe=UTF-8
Mean Green
https://www.google.com/search?q=mean++green&client=safari&rls=en&source=lnms&tbm=shop&sa=X&ved=2ahUKEwia-MTm7p_rAhVS7qwKHYnpAkQQ_AUoAXoECA4QAw&biw=1280&bih=963
( mean green is strong stuff. Use only with rubber gloves )
Zep Industrial Purple
https://www.tractorsupply.com/tsc/product/zep-commercial-industrial-purple-cleaner-degreaser-concentrate-128-oz
( use rubber gloves. Wear a mask or hold your breath. )
Purple Power
https://www.homedepot.com/p/Purple-Power-1-Gal-Cleaner-Degreaser-100539322/308623047?mtc=Shopping-B-F_D28I-G-D28I-28_4_CLEANING-MULTI-NA-Feed-LIA-NA-NA-BASE_SHP&cm_mmc=Shopping-B-F_D28I-G-D28I-28_4_CLEANING-MULTI-NA-Feed-LIA-NA-NA-BASE_SHP-71700000041074444-58700005459736589-92700049810295128&gclid=EAIaIQobChMI7cKNlvCf6wIVzcDACh0ltA2LEAQYASABEgKVcvD_BwE&gclsrc=aw.ds
For best action, let the parts soak for awhile.
Other cleaners will probably work just as well. These are the ones I am familiar with.
If you are wanting real shiny metal, get a buffer machine.
#983 72 days ago
No i just used the Mag and Aluminum polish at the end. Most of the work was the Tumbler and a scotchbrite flap wheel for the larger parts.
Quoted from cottonm4:
I thought i had some spray clear on hand but all i had was Triple Thick. When i moved the moving company wouldnt allow any type of flammables or paints. Which is a bummer as i lost all my pinball goodies incl my Molotow paints for F2K stencil job
As for waxing the land for the drops i had never heard that tip. So thats what i’ll do next. I think i have some mylar i can use for the drop target faces also thanks Cotton.
#984 72 days ago
Triple Thick will work. All it is is clear with more solids in the mix.
#985 70 days ago
Just got this in from greatwichjohn and it looks really good!
#986 56 days ago
There is a nice new Seawitch playfield with about 5 lenses off for alignment. Likely one of the early tests to dial in cnc & art. $400 US shipped to USA. If you have a beater this is a great deal!
#987 53 days ago
So I've replaced the mpu with an alltek and I am still seeing 22's instead of a 0 at boot. Any ideas champions?
#988 53 days ago
Quoted from Marv:
So I've replaced the mph with an alltek and I am still seeing 22's instead of a 0 at boot. Any ideas champions?
Disconnect all but one of the displays. If it still happens, swap that last display for another. If it still happens, you have an open circuit on the display BCD data 1 signal from the MPU board at pin 26 of J1 to all the displays at pin 18. This is a Blue-White wire that gets daisy chained from one display to another on pin 18. More likely you have a bad crimp terminal connection at the source MPU board pin 26 of connector J1.
#989 52 days ago
Those stupid pal nuts are garbage throw them in the trash. Just use the nylon or rubber ones. Those pieces of garbage always grab the stud and pull the whole thing out. I hate them so passionately it’s difficult to put into words.
Mine are all blue but I bought an original playfield that was junked and it was all yellow. Probably just whatever Stern got a good deal on at the time.
#990 47 days ago
Quoted from Quench:
Many thanks for that I owe you a beer. It was pin 26 on the connector after all.
Next question is there any modifications to be done to make the loop shot more accessible?
#991 46 days ago
Quoted from Marv:
Someone (probably earlier in this thread) made a solid gate for the right that flips in and out so you can get a more solid shot on it.
I don't think the loop shot is the money shot in this game anyway, it's max 22k. Max the bonus and milk the drops for the 39k intead.
#992 46 days ago
Quoted from Marv:
I don't own a Seawitch but if I did, I'd probably move the left post a touch as mentioned here:
https://pinside.com/pinball/forum/topic/any-seawitch-fans-on-pinside/page/16#post-5451065
https://pinside.com/pinball/forum/topic/any-seawitch-fans-on-pinside/page/16#post-5455268
And also experiment with changing that upper left flipper for a 2 inch bat.
#993 30 days ago
Hey guys, I've only been in the hobby a few years now. I have only had Williams system 11's and WPC machines up to this point. I've been offered a Sea Witch that doesn't boot but appears to be in nice shape. The only thing I know is he has had it since the 80's and a couple years ago it would boot if he turned it on and off quickly. What is the most you guys would pay for a non working Witch in today's market? Any things I should be looking for on early Stern's? I'm going to go look at it Tuesday night and want to be prepared as possible. Thanks.
received_2741287562787326 (resized).jpegreceived_634265577478413 (resized).jpeg
#994 30 days ago
Show pics of the boards.
#995 29 days ago
Quoted from Tomass:
This is all I have at the moment. I'm going to assume there is acid damage since he seemed surprised when I asked about batteries.
$ 349.95
Pin Stadium Pinball Mods
$ 259.95
